RV.Net Open Roads Forum: need wiring diagram for parallax 7300 series converter
 > need wiring diagram for parallax 7300 series converter
jesien24
Pa/USA
Posted: 07/15/10 04:48pm Link  |  Print  |  Notify Moderator
We had a magnetek series 6300 A model 6345that stopped working and found it that the parallax took it over. So we got the 7300 series and need the wiring diagram. We also have a solar panel on the roof that I am thinking need to go to the converter also. Any help would greatly be appreciated. Our motor home is a 1992 fleetwood jamboree searcher.
thank you in advance,
Sandy
chaffeekid
Chaffee, Mo, USA
Posted: 07/15/10 08:07pm Link  |  Print  |  Notify Moderator
Hi there, well I just recently converted mine from the old 6345 to the new up graded version with the intelli wizard charger, (don't hold me to that spelling).
In stumbling around on the web, here's what I found for you and hope it will help.
Installation wiring for 7300 series.Hope this helps.
Happy Trails
Jim
MGySgt USMC(R) 61-91">
N0LZS
Wife, has put up with me for 50 years ">
Three hyper chihuahua's
Good Sam a pound rescue, Sassy and Bambi
2001 Fleetwood Expedition Diesel Pusher
Toad 2013 Jeep Wrangler Sierra hardtop
MrWizard
Traveling
Wire solar panels to battery, or to controller then battery
Do not put extra resistance in the solar charge circuit by going thru the converter and using the converter wire for.the.solar.charge , too much voltage drop and.power loss
Radiate The Happy
1997 F53 Bounder 36s
jesien24
Pa/USA
Posted: 07/16/10 05:01am Link  |  Print  |  Notify Moderator
We just got the lower unit ,just the converter. Ours has 3( looks like 3) wires and the new converter has 2( blue and white one)
thanks
Sandy
jesien24
Pa/USA
Posted: 07/16/10 07:41am Link  |  Print  |  Notify Moderator
I guess we need the 7345 RU which is the kits that comes with the fuses and instructions
ryanallie1
Fall River Mills, Calif
Posted: 07/16/10 07:59am Link  |  Print  |  Notify Moderator
Hi All.
I just finished installing the new 7355 RU in our Motorhome not long ago. What a big differace in preformance. Plus its so quite, that you don't even really hear the fan when it does run. Its also much kinder to your battries. Faster charging time. And doesn't boil your battries, as the old 7340 did. Its a simple direct change out. No problems at all going from a 40 amp to a 55 amp. It shows that you can get the 7345 RU or the 7355 RU. Good Luck. Happy Travels. Dan & Jill
1998-34 ft Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
