Open Roads Forum
Print  |  Close
Topic: Fuel Station Repair/Rebuild
Posted By: JFJ on 07/27/10 07:45am
Last week I posted "Fuel Station Replacement" and thanks to you all, it has now turned into "Fuel Station Repair/Rebuild". First of all, I had my 2005 Raptor 3612 DS at my mechanic to get my generator running. He said that the methanol content in the gas does some bad things to carburetors unless you use the marine grade (green) Sta-bil. He also thinks it is responsible for the gear swelling in my fuel station that prevented the pump from working, as well as ruining a seal.
Now to the fuel station issue...originally he took it apart and said the motor was working fine, but the the pump would not work b/c the gears had swollen. He said it needed a new pump to the tune of a/b $300...ouch!! That's when I made my original post. Thanks to Wild Bill, I was able to contact Graco. Their customer service number is 800-533-9655, option 5. The pump was originally made by PBL who has been taken over by Graco. My pump model was an FP12. Turns out that I needed the gear kit (Part number 260277) and a seal that goes around the motor shaft that drives the pump. The seal only comes in a kit, so I also had to get part number 260434. If your seal is not bad, then you may not require both kits. Here is the good part...the gear kit only costs $14 and the seal kit only costs $9. Trust me, I am not mechanically inclined, but I could repair this myself. You take 4 bolts off of the pump cover and pull out the two gears, replace a gear key or drive (pull out the old key and insert the new one from the kit), put the new seal (again, from the kit) on the pump cover and then put the 4 bolts back on again. Voila!!! A $300 pump replacement just turned into a $25 repair!!
One thing you need to know...Graco only sells through local distributors so you can't buy directly from them. They will tell you who carries their parts in your area. I live in Memphis and there were only 3 distributors, none of whom carried the parts. It takes a/b a week to get them.
Thanks to Wild Bill and the rest of you who gave me the information to go out and research this for myself. Not only did I save a lot of money on the repair, but I now know how to do it myself. Thanks to you all for your help. I hope this helps someone else who is having the same issue with their fuel station.
2007 Dodge Megacab 2500 4X4 SRW
6.7 Cummins w/6 Speed Auto
2005 Raptor 3612ds
Pacbrake Air Bags
Prodigy Brake Controller
Pullrite Superglide 24K
Posted By: rocmoc on 07/27/10 08:25am
Excellent info / post & Thanks. Also Thanks to Wild Bill. I have made a copy and filed in my Raptor folder for future use. Thank you again!
rocmoc n AZ/Baja
rocmoc n Southern AZ/Mexico
Posted By: SAR Tracker on 07/27/10 09:18am
Another thing that can be done (in a pinch) is to remove the gears, and sand them down just a little (less than 1/32"). The swelling occurs across the width of the gear, not the circumference. Just take a piece of sandpaper, lay it on a flat surface, and rub the gear on the sandpaper in a figure-8 pattern (evens out the sanding marks, if any). Then re-install the old gears.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
Posted By: jeffws on 07/27/10 10:13am
Thanks for the info. My pump just started leaking......
00 FLHR
03 XR 50
05 CRF 70
03 XR 80
05 CRF 230F
06 Yamaha Rhino
06 KTM 525 EXC
05 F-250 CC,4X4,6.0 PSD
06 Gearbox 295FS
05 Carson 7x10
Posted By: barry&vanda on 07/28/10 12:30pm
Good for you, JFJ! My fuel pump by GPI died 1 WEEK after the warrantee was up. It was actually the motor itself. Fortunately I have a local electric motor rebuilder to rely on.
Honk at any silver Dodge Ram & Crossterrain toyhauler on Baja. It's gotta be us - 'specially if it says Baja and Back #1.
05 Dodge Ram 3500 Diesel 4 by w/10,000 lb winch
09 TF34MK Crossterrain toyhauler
12' Portabote w/Yammy O/B.
08 Honda Rancher ES
Posted By: River&Sand on 07/28/10 09:18pm
Welcome to the dead fuel pump club! Most of us have experienced it at some point, usually at the most inopertune time. Mine came in the dez with 25 gallons of race gas in the tank and no way to get it out. Now I keep a spare set of gears both new and an old sanded set. Another failure point is the plastic key that holds the plastic drive gear on the shaft. Had that break too on a friends pump.
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, HappiJac, Jordan 2020
05 Lance 920 Truck Camper
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex ">
01 HighJumper SandSprite 3 Dune Buggy ">
Posted By: ethand on 08/24/10 03:53pm
My FP12 failed recently and found this thread while doing a search. I have had little luck finding the parts locally as well. Can someone post the contact info of where you found the parts so I can do the same.
Thanks
E
Posted By: nayther on 08/24/10 04:08pm
That's always scared me too so I carry one of those siphon deals, "just in case".
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Posted By: cobyco on 08/24/10 05:17pm
I replaced my gears and it worked great for 3 yrs, then it started blowing the fuse again, Replaced gears again and it still blew the fuse, I figured out it was a bad motor So I just received a nice new Graco Blue devil pump today from unionhydro.com 265.00 it also includes a new pump nozzle and a longer hose, I hope it works![emoticon]
2006 RAGEN 3005 5TH
1999 DODGE 2500 V10
Firestone Airbags
Awsome Wife
2 yellow Labs Cooper & Kona
2001 WR 250 mine
2003 CRF 230 wifes
2006 Twister HammerHead SS
Posted By: McKenziek on 08/24/10 05:31pm
Thanks
E
Ditto for the GPI EZ8-RV pump. I sanded the gears but want to keep a spare set on hand.
Their website lists the overhaul kit as part # 13750005 http://catalog.gpi.net/item/fluid-transf......../pn-9542?&plpver=1001&bc=1097|1308|1234y but with no means to buy it. Great customer service GPI.
2005 Monaco Diplomat
Posted By: nvreloader on 06/10/11 01:24pm
Hey MOD,
IS there any way that this complete post be made into a STICKY so the info is not lost.
Tia,
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
Posted By: DunDoneIt on 06/10/11 05:17am
VetPartTimer wrote:
My pump quit working recently too, but I have no idea what the problem is, maybe this is it.
When I turn on the timer switch, nothing. Before you could hear the timer running and then outside at the pump you could hear that the pump was on.
I checked the fuze box, all fuzes are good.
Could this be my problem?
Just try loosening the 4 bolts and see if it starts. Mine is still working good and all I did was sand the gears. See the above posts I made.
2009 Fuzion 302 2003 Ford F-250 4X4 Crew Cab Short Bed
2009 Polaris 850 XP Limited Edition 2011 Polaris EV LSV
Pictures Fuzion 302
Pictures Polaris 850 XP LE
Posted By: Clay_III on 06/07/11 09:16pm
Took my 05 PlayMor Renegade TB into the shop for its annual Roof treatment and inspection (cheap insurance to keep the lifetime warranty in force, cost to much to replace it again). While they had it, asked them to take a look at the Fuel pump. Needed some fuel and discovered the pump would only hmmmm. Worked 2 weeks ago. Anyway, shop calls and tells me that the manufacture of my pump is no longer in business and they cannot find a replacement anywhere. Asked for the model number (FB12) and began my search. 1st stop, RV.net, quick search through 5th Wheel TB section and found this thread. Called Graco, they told me the Graco replacement P/N. Called the shop back 20 minutes later with the info and they were off getting the pump.
Enjoy reading through the sections and actually have incorporated some of the suggestions into my TB. Thanks for the tips and keep them coming. You never know when it helps someone else out.
Thanks again.
Posted By: VetPartTimer on 06/07/11 07:10pm
Posted By: strlw on 06/03/11 10:02am
Here is link that looks like replacement gears.
http://store.gpipumps.com/ovkiforez.html
Posted By: DunDoneIt on 04/30/11 09:46pm
Thanks for the info on sanding down the gears.
Saved me a trip to the repair shop. I measured the gear and they were .755 and I figured they should be at .750. Sanded them down got them just under .748.
Pump working great now.
Just thinking how much it would have cost me in fuel alone just to go to the service center 150 mile round trip.
I first loosened the 4 bolts holding the gear and the pump did not leak but did start pumping. That told me it was the gear swell as others have found.
Posted By: tinner12002 on 05/01/11 03:43am
Well, Graco seems to know what the problem is now lets see if they fix it.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
Posted By: mrxlh on 05/01/11 07:33am
The permanent fix is bronze gears. Which would probably make that pump $450.00 instead of $265.00. At least it is repairable.
Ryan
2008 Ford F350 CC LWB Dually
2011 Raptor 4014LEV
2006 H-D FLHX
2010 Honda Rancher 420ES
Posted By: DunDoneIt on 05/01/11 09:05am
Here is a breakdown of the GPI EZ8 pump.
An easy way to quickly get your pump running would be to loosen the 4 bolts (#2 in diagram) on the end cap that has GPI cast into it. It takes a standard 1/2 wrench or socket. Just loosen it enough to break them loose. The o-ring should not leak unless you loosen too much. If your pump starts working you need to sand your gears.
I had some 220 grit drywall open mesh paper and used it on a steel table. It took more pressure to remove material than I thought it would. You can sand some off and refit gears and try it to see if it works with the bolts tight. It does not take long to remove the gears once you get to the motor. Just watch for the small key (#17 in diagram) that drives the gear off the motor.
Posted By: alarmin on 08/24/10 05:54pm
I have the EZ8-RV pump and the gears were swelling across their width as stated. I was replacing my pump and hooked the old pump (removed and on my work bench) to a 12vdc source and nothing (just sparks). Then I removed the cover over the gears and it worked great and I could see the scoring inside the cover. Sanding the gears or possibly even adding a thin gasket to the gear cover could make all the difference needed.
Posted By: mapguy on 08/25/10 09:31am
McKenziek wrote:
Thanks
E
Did you call GPI @ 1-800-835-0113
Posted By: FRANK M on 08/27/10 04:20pm
This has happen two times in five years for me. I just sand the ends and it works fine after that!
2004.5 Dodge Ram 2500 4x4 LB,4 door w/Cummins,48re.Banks,Auto meter gauges,Airaid filter kit,Super lift leveling kit.B&M Deep Pan.
1994 Thor Residency 3500
1983 Jeep Cj-7
1987 Suzuki Lt 500
2008 Polaris 800efi Touring
1988 Kawi. Kx 500
Posted By: dadwolf2 on 08/27/10 06:21pm
You just sand the ends to make it a little less wide at the outside of the plastic gears?
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Posted By: TEXMudder on 03/15/11 08:04pm
Dumb question for you that have serviced the pump before. Mine is locked up and I plan on replacing the gears. But, to get me through my next trip, I plan on sanding the gears. When I remove that cover, how much gas will come out? Do I need to pinch off the lines first or will I just lose a bit into a bucket and then be good to go?
Posted By: tom cav on 03/15/11 08:44pm
very little fuel will come out ,i just had a few shop rags
2007.5 cc,sb.ltz 4x4 d/a"> ,o9 eclipse stellar 34 lksg 2012 xp-4, 08 4seat rhino . yamaha 125 grizzly 125 breeze
Print  |  Close
