RV.Net Open Roads Forum: LIFAN 2200 Watt Inverter Generator Electric Start Video
 > LIFAN 2200 Watt Inverter Generator Electric Start Video
McZippie
Posted: 07/27/10 02:53pm Link  |  Print  |  Notify Moderator
Purchased from Home Depot the LIFAN 2200 Watt Digital Power Inverter Generator with Parallel Port, Electric Start, Portability Kit, Model # ESI2000iE-CA.
Posted a Video on YouTube of it, starting, running and under load, powering a water heater at 11.50amp/1400 watts, in the the auto eco mode.
Lifan 2000iE YouTube Video Link
Home Depot Link
9/1/10 update:
Bench Test without covers, running from aux fuel tank, extended exhaust pipe. Sorry about the crummy cell phone out of focus pictures.
Install update Nov. 9, 2010:
Total cost about $1,000. including the cost of Generator ($600)
Noise level is acceptable.
* This post was last edited 03/03/11 03:08pm by McZippie *   View edit history
2009 Ford E350 Diesel Cutaway Limo Bus
2010 Jeep JKU Rubicon (Toad)
1942 Bantam T3 Trailer
mena661
Posted: 07/27/10 05:18pm Link  |  Print  |  Notify Moderator
Awesome!!!! Thanks much!!
Trojan L16 6V's 740 Amp-hours
pianotuna
Regina, SK, Canada
Posted: 07/28/10 07:22am Link  |  Print  |  Notify Moderator
Hi,
How tall is it? My darn storage is 17" opening and 19" inside.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
McZippie
Posted: 07/28/10 08:20am Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
Rounded up to (L x W x H), 20" x 11" x 19.5"
The Honda 2000i is(L x W x H), 20.1" x 11.4" x 16.7"
I plan on taking all the plastic covers off and mount it under my rig, between the rear fender skirt and frame with a separate gas tank between the frame rails and the starting controls inside the MH.
This could knock a few inches off the overall height.
beemerphile1
I'm 57, I'm not a
Posted: 07/28/10 09:50am Link  |  Print  |  Notify Moderator
I wonder why that is so much different than what is listed on the HD website;
* Assembled Depth (in.) : 23 in
* Assembled Height (in.) : 13 in
* Assembled Width (in.) : 20 in
* Item Weight : 59 lb
Even if you are on the right track, you'll get run over if you just sit there.
- Will Rogers, American actor
pianotuna
Regina, SK, Canada
Posted: 07/28/10 10:06am Link  |  Print  |  Notify Moderator
Hi beemer,
It is because Home Depot "got it wrong". They sent me an email apologizing for the error--but they obviously have not made a correction yet.
ATS_Aaron
Denton, TX
Posted: 07/28/10 01:27pm Link  |  Print  |  Notify Moderator
GREAT video. I wish there was a commentary at the beginning so I could get a reference on how loud it really is. Doesn't seem too bad in the video though.
Aaron
McZippie
Posted: 07/28/10 01:49pm Link  |  Print  |  Notify Moderator
Aaron
Yep, I know what you mean... When I get time, I'll do a video of it running under load next to a lawn mower to help judge the difference in sound volume.
Until then, it's a lot quieter than a mower but louder than a Honda 2000i. I think it could be used anywhere someone would be comfortable running a Honda 2000i.
* This post was edited 07/28/10 04:19pm by McZippie *
McZippie
Posted: 07/28/10 01:53pm Link  |  Print  |  Notify Moderator
I too saw those numbers on the Home Depot site and knew they were wrong, my actual measurements should be within a 1/4" of correct.
McZippie
Posted: 11/09/10 01:22pm Link  |  Print  |  Notify Moderator
See above picture;
Finger is pointing at choke, on top of transfer switch box.
Also extended the keyed starter controller switch wires from the generator to transfer switch box.
Most time consuming part of project was chasing down and purchasing all the extra parts.
