Received some inquires about the exhaust system so I'll post the info here:
Starting from the Lifan:
A conduit coupler smashed onto the Lifan exhaust outlet, set screw filed to point, small indent made to Lifan exhaust outlet, set screw tightened into indent.
A short piece of conduit pipe into coupler, same set screwed set'up as above. The conduit pipe extends out 2 inches.
Stainless Steel flexable exhaust pipe, left over from the installation of Espar Airtronic Diesel Heater. Attached with hardware store U-clamp. I think it's 30mm stainless steel. Here's a UK link, I couldn't find a source in the US. Clicky Let me know if you find any in the US.
Automotive exhaust pipe hanger with rubber flex piece, large clamp was discarded and replaced with conduit pipe hanger.
Tip made from conduit compression coupler cut in half.
