RV.Net Open Roads Forum: Tech Issues: Reversing a Winegard Sensar
 > Reversing a Winegard Sensar
eric1514
AZ ID
Posted: 07/28/10 01:00pm Link  |  Print  |  Notify Moderator
Hi all,
I want to get a Wingman for my Sensar but in the retracted position, I don't think I have enough room between the Sensar and my AC.
However, if the whole head of the Sensar was on the other side of the two legs that rise up, I'd have plenty of room. This would entail taking the plastic housing parts off and flipping them over.
Can this be done?
TIA,
Eric
2015 Travato 59g
chipper
Nampa,Id
Posted: 07/28/10 04:09pm Link  |  Print  |  Notify Moderator
In a word, yes
gene
SCVJeff
Santa Clarita, CA.
Posted: 07/28/10 08:08pm Link  |  Print  |  Notify Moderator
chipper wrote:
In a word, yes
I'd like to see this. Winegard says NO, and my batwing won't flip without a serious Dremel session.
Jeff - WA6EQU
jcthorne
Houston, TX
Posted: 07/29/10 11:33am Link  |  Print  |  Notify Moderator
I tried this. Took the batwing all apart trying to flip it. The pivot joint is not semetrical and grinding out enough of it to allow reinstallation in the opposite direction will not leave enough to be structually sound. the batwing is now standing in my garage and we replaced it with a new antenna that uses the same lift mechanism and works all HD channel range.
2008 Damon 3575 (38ft, forward kitchen)on Ford 22k chassis
eric1514
AZ ID
Posted: 07/30/10 04:49pm Link  |  Print  |  Notify Moderator
jcthorne wrote:
...the batwing is now standing in my garage and we replaced it with a new antenna that uses the same lift mechanism and works all HD channel range.
Who makes this? Got a link?
Eric
SCVJeff
Santa Clarita, CA.
Posted: 07/30/10 05:03pm Link  |  Print  |  Notify Moderator
Eric
Probably the JACK Antenna. It supposedly fits on the batwing mast. I wouldn't just swap the batwing out because I think it's an overall better antenna, but you have a reason.
Fredzo
SoCal
Posted: 07/31/10 01:01pm Link  |  Print  |  Notify Moderator
OP: Can you just shorten the tubes a bit to miss the AC? Some folks have done this successfully.
2005 Georgetown 342DS XL
1989 Wrangler Sahara Toad
2005 Liberty Renegade Toad
Blue Ox Tow Bar, Brake Buddy
Retired on Jan 1, 2010!!!
taylor-rob
Burbank ca
Posted: 08/13/10 07:42pm Link  |  Print  |  Notify Moderator
I just finished mounting a Sensar IV in the opposite direction . It took about two hours but now that I know how to do it, it would take less time. I have some pictures but not sure how to post. Contact me if you would like to see my job. crt-innovations@sbcglobal.net
* This post was last edited 08/14/10 12:45am by taylor-rob *   View edit history
Rebel Rob
eric1514
AZ ID
Posted: 08/13/10 08:44pm Link  |  Print  |  Notify Moderator
Not a bad idea. I'd have to take about a foot off, but I can't see it making any difference.
Eric
FoxFifth
Dallas,OR
Posted: 08/14/10 11:12am Link  |  Print  |  Notify Moderator
I shortened mine about 8 inches. I just removed the head, put some heavy cardboard under the mast in the down position, cut the same length off of both tubes, drilled 2 new attachment holes at the top of the tubes and drilled a new hole where the coax exits the tube near the top. Hardest part was finding a drill bit exactly the right size for the coax hole so the protective bushing would fit.
