Hello everyone. We have a 96' Safari Cont. and are wondering if anyone knows how many lbs of freon the dash air conditioning takes?We havent any manuals, and the tech said he needs to know.. thanks in advance. mary
If he were a real tech, he would probably look on the manufacturers plate that's usually attached somewhere on the evaporator. Personally, I think i would find another shop. In a pinch, he could charge it until the suction line sweats back to the compressor, watching the pressures on the guages. The properties of refrigerant are the same regardless of what equipment it's in. Tell him it's going to take R-134a, in case he doesn'tt know that.
GM (Chevy) P-30, L-19, L-29, L-65 2.75 Lbs.
GM (Chevy) P-12 w/Parallel-Flow Condenser 2.0 Lbs.
Workhorse before '05 model except W-24 2.75 Lbs. (1)
Workhorse - all models with black Behr condenser and two fans 2.00 Lbs.
Workhorse W16D/W20D Front Diesel 1.75 Lbs.
Workhorse W22/W24 w/Multi-flow Condenser and no fans 1.5 Lbs.
Ford E-33 w/Serpentine Condenser 2.25 Lbs.
Ford F-53 w/Fin & Tube Condenser 2.75 Lbs.
Ford V-10 Super Duty w/6mm Condenser 2.75 Lbs.
Freightliner Front Engine Diesel w/Parallel-Flow Condenser 1.5 Lbs.
Freightliner Front Engine Diesel w/remote mounted condenser and fan 2.25 Lbs.
(1) For W22 without an auxiliary condenser, charge would be 1.75 lbs and performance would be reduced.
STEP VAN APPLICATIONS
GRUMMAN OLSON / MORGAN OLSON
CHASSIS CHARGE
Freightliner Front Engine, Gas or Diesel 1.50 Lbs.
GM (Chevy) P Series/Workhorse, Gas or Diesel 2.25 Lbs.
Workhorse 8.1 L Gas 2.00 Lbs.
Workhorse with International Engine 2.00 Lbs.
Navistar V-8 Diesel 2.25 Lbs.
Ford 2.25 Lbs.
UNION CITY BODY CO.
CHASSIS CHARGE
Workhorse, Gas or Diesel ***Prior to 6/2/2002 (small R/D)*** 2.75 Lbs.
Workhorse, Gas or Diesel ***After 6/2/2002 (large R/D)*** 3.50 Lbs.
A real mechanic would look for the tag on the unit and if none available, he would charge it using the gauges. Sounds like he is a parts changer....not a technician.
ken
Amateur Radio Operator.
Vintage 1989 Avion Silver, 34V, toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with one miniature Schnauzers, one standard schnauzer and one African Gray parrot. Practicing for retirement!
