RV.Net Open Roads Forum: Class A Motorhomes: Handicap Toilet
 > Handicap Toilet
drifterpilot
Gloucester, Virginia
Posted: 08/05/10 09:14pm Link  |  Print  |  Notify Moderator
Need some advice here.
Presently, we have a factory-installed Dometic Sealand toilet, pedal flush with a hand spray. It is 17.5 inches high up from the floor.
We wish to install a handicap (higher) toilet. I called Mobility RV, no help. I called Camping world, no help. They advised me to call Dometic, no help. Dometic advised me to call Sealand, again no help. Dometic stated there is no handicap gravity-drop toilet in the Traveler Series.
Where do I go now?
In my 1st coach, 2001 Monaco LaPalma, I had a dealer install a high handicap toilet, so I know they are "out there."
Surely there is somebody that has a handicap toilet in a Winn. Adventurer or same line.
2003 Winnebago Adventurer 33V
97,000 miles
Workhorse W20 Chassis
Vortec 8.1, Allison 1000
Kingdome (in-motion tracking)
Bilstein shocks (installed July 2013)
Safe-T-Plus Steering Stabilizer
Blue Ox Adventa II and KarGuard
Brake Buddy
2017 Malibu LT
Golden_HVAC
Fulltime, CA, USA
Posted: 08/05/10 09:27pm Link  |  Print  |  Notify Moderator
Hi,
In my motorhome, there is a sort of shelf that the toilet sits on, I guess because the toilet needs to make a tun in the plumbing below the toilet, close to the dual rear wheels, and above the black water tank. So I have a super short toilet that sits on a 4" high shelf.
I don't know if that will help at all, yet you might be able to mount a shelf, cover it in floor tile, and then mount the toilet on top of that.
If you want to look at a RV like mine, check RvSearch.com and look for Fleetwood 30' long. I have a Bounder, Pace Arrow and Southwind should have the same layout. You might find one for sale near your hometown. I have a 97, and the same floorplan was used between 95 and 1999, perhaps a few more years either side of those 5.
Good Luck,
Fred.
ronfisherman
SE Michigan
Posted: 08/06/10 04:33am Link  |  Print  |  Notify Moderator
You can install a 2 1/2" riser. Thetford riser.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
SKIPPERS_1
INDIANA
Posted: 08/05/10 09:40pm Link  |  Print  |  Notify Moderator
My Mother in Law TRAVELS WITH US ,we went to walgreens and purcHASED
an adjustable leg portable toilet, I can adjust the legs to different heights front and back it works great and folds up when not needed.
1999 DUTCHSTAR DP
38`
8.3 ISC CUMMINS
SPARTAN CHASSIS
1994 TRACKER 4X4 TOAD
BLUE OX TOW BAR
Tinstar
McKinney, TX
Posted: 08/05/10 10:47pm Link  |  Print  |  Notify Moderator
Why don't you just install the same toilet that you had in your 2001 Monaco LaPalma. Either that, or make a riser for the one you have. Plumbing stores have all the parts you need.
">Never pass up a chance to go somewhere">
kalynzoo
Los Angeles , California
Posted: 08/05/10 10:55pm Link  |  Print  |  Notify Moderator
If you visit a well equipped Hospital/Convalescent supply store you will see a wide selection of toilet accessories. An adjustable 4 legged support that fits over the toilet and extends a sleeve into the bowl permits a higher seat and firm support when rising. An example of some of the many assistive options can be seen here: http://www.toiletology.com/handicap.shtml
Tinstar
McKinney, TX
Posted: 08/06/10 12:27pm Link  |  Print  |  Notify Moderator
bsinmich wrote:
I got my wife a handicapped toilet for home for our anniversary
Ohhhhhhhh, how romantic. I bought my wife a new push mower for our anniversary.
rgatijnet1
Posted: 08/06/10 12:46pm Link  |  Print  |  Notify Moderator
I got my wife a vacuum cleaner on an anniversary. Big mistake!!!! [emoticon]
rgatijnet1
Posted: 08/06/10 05:30am Link  |  Print  |  Notify Moderator
Any of the medical supply houses can get you one of these which will fit around your existing toilet.
bsinmich
Holland, MI
Posted: 08/06/10 05:33am Link  |  Print  |  Notify Moderator
A normal home toilet is 14" and a handicap is 17". It sounds like you already have that. Would an assist bar be of some help? In addition to the risers that are nade by Thetford you may find a seat with a lift already built in. I got my wife a handicapped toilet for home for our anniversary and the next year had to get her another one for the basement.
1975 GMC Eleganza II & 1995 Roadtrek Versatile. Both old enough to vote and drink (gas)
 > Handicap Toilet
