RV.Net Open Roads Forum: RV refrigerator not cooling, but freezer works fine
 > RV refrigerator not cooling, but freezer works fine
jimmersmom
New York
Posted: 08/09/10 07:46pm Link  |  Print  |  Notify Moderator
I have a Dometic DM2862 refrigerator unit. Turned it on last night. The freezer works great, but the refrigerator isn't cooling at all. Any ideas?
Norm Payne
Livingston, TX
Posted: 08/09/10 08:17pm Link  |  Print  |  Notify Moderator
If the freezer is down to zero degrees it is working properly. If it is just freezing water it is not working OK. Refrigerators / freezers can take 24 hours or longer to cool all the way down. If you put some jugs of water in the refrigerator it will cool down quicker and hold its temperature better.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
Ivylog
Blairsville, GA and WPB, FL.
Posted: 08/09/10 09:14pm Link  |  Print  |  Notify Moderator
Welcome to the forums. The refer section gets the cold that's left over from the freezer and often it takes 24 hours for the refer to get cold. For the unit to work properly, the freezer has to get close to 0 degrees (not just cold) and then the fins in the refer will get 27-30 which will get the rest close to 40. Putting frozen jugs of water in the refer section will speed this up. In that little Search box at the top is a lot of info like this when I searched for "freezer cold but".
08 Holiday Rambler Navigator 45'
How I tow.
Towing a Prius without a dolly
Where am I?
How I spend the winter.
Gale Hawkins
Murray, KY
Posted: 08/09/10 09:50pm Link  |  Print  |  Notify Moderator
What are the temps of each box after running overnight without opening the doors?
Ringer
Elkton, Maryland
Posted: 08/10/10 04:25am Link  |  Print  |  Notify Moderator
Can't tell you this from personel experience but an rv tech. once told me a fridge will cool down faster by running off of LP rather than AC.
2016 Allegro Bus 40AP
2008 Saturn Vue
Gale Hawkins
Murray, KY
Posted: 08/10/10 08:20am Link  |  Print  |  Notify Moderator
I have heard the same thing but hopefully I will gas back to our 6162 Norcold and I will test to see in our case if that is fact or fiction. I have my electric cool down times recorded.
jimw606
Morehead, Ky.
Posted: 08/10/10 10:20am Link  |  Print  |  Notify Moderator
I was having a problem getting my Dometic to cool down in the fridge. I kept sliding the thermistor up on the inside coil fins, until it worked OK. Jim
revrnd
Apsley, Ontario
Posted: 08/10/10 10:28am Link  |  Print  |  Notify Moderator
X2
I was trying everything out on my new TT this spring. It made ice cubes all right but the fridge was still warm. Then I noticed the thermistor was closer to warmer than cooler. Adjusted it towards cooler & everything was fine.
Unfortunately there is no mention of this in the Dometic manual that accompanies the fridge.
1986 Monte Carlo SS
2011 Chevrolet K2500HD (P3 controller, Husky WD hitch)
2009 Rockwood 2106 Mini Lite
Retired GM of Canada Oshawa Truck Assembly Plant
Opened 1965 Closed 2009
Gale Hawkins
Murray, KY
Posted: 08/10/10 12:18pm Link  |  Print  |  Notify Moderator
Would not just slipping the thermistor off make one go to MAX cold mode as a quick test to rule out cooling unit problems?
