RV.Net Open Roads Forum: Workhorse Check ABS idiot light & message center warning
 > Workhorse Check ABS idiot light & message center warning
njdirt
Monroe,NJ
Posted: 08/24/10 07:36pm Link  |  Print  |  Notify Moderator
Tried a search on this but found nothing. Today leaving from home when drove around block had these lights come on in an 06 22 Workhorse 6 speed Allison. Had my local truck mechanic(not authorized by WH) hook his computer to see if any codes showed for the problem and read nothing. I and DW were concerned knowing the recall on brakes etc. He looked at them and looked good and that the ABS has nothing to do with the brake system and should be OK to go on our trip. Drove 300 miles with no problems and no brake fade whatsoever with minor braking and hills(using the grade brake when on back roads).
Has anyone else had this and what should we do??? Any help appreciated.
Thanks Bob
Bob/Marlene and Crystal(Golden Retriever)and sometimes Grandkids....
37' Alllego Bay
dirts for racing/asphalt's for getting there
ctpres
Summer - Creede, CO Winter - Okeechobee, FL
Posted: 08/25/10 04:59am Link  |  Print  |  Notify Moderator
Holding foot on brake AFTER shutting engine off created similiar problem on our WH 8.1
A "Retired" Mind is a Terrible Thing to Waste
Chuck USNR, USAF & USCGA and Suzie
Challenger Owners Club
2015 Thor Challenger 37KT
2014 Ford Fiesta
2011 Sea Eagle 385 FT kayak
2009 Polaris RZR
2014 Zenetto Stealth road bike
ChrisFSB
CA
Posted: 08/25/10 10:29am Link  |  Print  |  Notify Moderator
Hi,
On the Workhorse UFO chassis I got the fright of my life coming down a 7% grade - the ABS, ATC, AutoPark, Stop and the warm fuzzy "Hydraulic Brake Failure" message all came on.
I pulled to the side (clearly the brakes were working) shut down the coach, waited 30 seconds, restarted - no errors. Called roadside assist - not much help - except they said maybe I had overheated the brakes (no chance - I was using 2nd gear to slow my descent - no braking).
Got the truck into a service center - they found that the right rear ABS sensor was bent and damaged. They replaced the sensor and fixed the bracket - no problems since.
Chris.
minisprint91
Hudson Ma.
Posted: 08/25/10 06:17pm Link  |  Print  |  Notify Moderator
If you go to this web site and go to tech-tips scroll down until you find ABS Sensor it will tell how to clean or replace the sensor its pretty easy to clean them.
http://oemys-performance.com/techtips5.htm#abs
I hope this helps
BrickBrain
Pearl River, La
Posted: 08/25/10 07:03pm Link  |  Print  |  Notify Moderator
I also use Oemy's website for various Workhorse tips. I have continuos issues with my ABS system. I think the problem w/ Workhorse is that the ABS sensors are not held in properly and they tend to back out of their socket. I always have to push them back into place. Usually I go ahead and remove them, clean them and re-install.
'03 Allegro 32BA on Workhorse W20
'06 Saturn Vue
Demco Aluminator
RM 9700 Brake
'02R1150RT B'mer
Dyna Beads
JaBob
Roswell, Georgia
Posted: 08/25/10 07:23pm Link  |  Print  |  Notify Moderator
I've had the problem with ABS light coming on for 4 years and haven't solved it yet. I've had everything checked and sensors replaced, cleaned and reset. I am assured light does not indicate a brake failure. Have never had the feeling of a brake failure.
I turn off engine and restart and light goes out. Mechanic said that action is resetting light. Bugs the hell out of me.
Bob
drifterpilot
Gloucester, Virginia
Posted: 08/25/10 09:12pm Link  |  Print  |  Notify Moderator
I have experienced a similar ABS light situation. I recently traveled from Virginia to New Hampshire over a two day period. I had a constant yellow ABS light on my dash the whole trip. I also experienced very mushy braking although I did have braking power with the pedal pushed down hard. I was traveling in 96 deg temp during this time. After approx 30 - 45 min, normal braking returned. I might add here, that prior to leaving Virginia I had flushed and reinstalled new brake fluid in my system.
When I arrived in NH, I took a look at the ABS sensors. The right front and right rear sensors appeared normal and tested 1200 ohms on my meter. The left front and left rear sensors were backed out of their bushings and were dangling from their connector wires. Each of the two sensors was blackened and greatly distorted (pictures available on request). Considerable heat, presumably from the brake rotor had forced the sensors completely out from the bushings installed on the wheels.
I was able to order from a trucking company, two ABS Meritor Wabco Sensor ABS Kits, Part No. #R955336. The kits were verified with workhorse as correct replacements. I installed same and am in the process of submitting paperwork to Workhorse for reimbursement.
I am now traveling in Maine with an extinguished ABS light.
As a matter of note, Workhorse now has established October 2010 as the date for the brake recall fix to commence.
2003 Winnebago Adventurer 33V
97,000 miles
Workhorse W20 Chassis
Vortec 8.1, Allison 1000
Kingdome (in-motion tracking)
Bilstein shocks (installed July 2013)
Safe-T-Plus Steering Stabilizer
Blue Ox Adventa II and KarGuard
Brake Buddy
2017 Malibu LT
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 08/26/10 12:14am Link  |  Print  |  Notify Moderator
Bob, I had a similar problem to yours and it was my ABS Sensor! Workhorse replaced mine for free! Good Luck, John
J-Rooster
Posted: 08/26/10 12:18am Link  |  Print  |  Notify Moderator
Bob, I looked up this number for you at Workhorse asked for Erika it's a toll free call 1-877-246-7731 and let her know what's going on with your coach. John
njdirt
Monroe,NJ
Posted: 08/26/10 04:38pm Link  |  Print  |  Notify Moderator
Thanks all for the help. I will try cleaning them tomorrow before leaving and see if that works.
