RV.Net Open Roads Forum: Fifth-Wheels: Broken Shackle
 > Broken Shackle
CentralCoastCampers
Central Coast, CA
Posted: 08/29/10 02:29pm Link  |  Print  |  Notify Moderator
Pulled into a campground for an overnight and smelled tire smoke when we stopped. Discovered the wheels on the right side of the trailer were touching. Further inspection revealed that the front shackle on the rear axle had failed. The bolt on the leaf spring had ripped out of the shackle, and the leaf spring was now sitting against the frame, shifting the axle forward. Luckily, the axle manufacturer listed their parts suppliers in their manual, and there was one within an hours drive. Took the damage shackle off, and spent a whopping $7.27 in replacement parts. Had the new parts on in less than an hour. The guy at the parts place said he had never seen shackle brackets fail like that, and say they didn't look like they had cracked or had a defect. It looked like the bolt might have gotten a little loose, it wore a bit, and then ripped through.
Here area couple of pics of the shackle and leaf spring before replacement. This isn't a part I inspected on a regular basis, but it is now. Just wanted to share so others might be able to prevent this from happening to them.
Pictures
* This post was edited 08/29/10 03:05pm by CentralCoastCampers *
'05 Keystone Challenger 34 TBH 5th wheel MOR/ryde SRE/4000, Dexter wet bolt kit
'05 HD Dodge 3500 DRW extended cab CTD, 4X4, 4:10 gears
Mike & Shannon
Son Kasey & Daughter Lindsay
Alaskan Klee Kai - Kade
Golden Retriver - JD (Just Dog)
BobsYourUncle
Calgary Alberta Canada
Posted: 08/29/10 02:48pm Link  |  Print  |  Notify Moderator
I don't see any pics . . .
Duramax / Allison
Fire Red
1997 Triple E Topaz 27' Bunkhouse TT
SWD
Land of Living Skies
Posted: 08/29/10 02:55pm Link  |  Print  |  Notify Moderator
Ditto BYU
CentralCoastCampers
Central Coast, CA
Posted: 08/29/10 03:06pm Link  |  Print  |  Notify Moderator
Had a problem getting the pics to work, so did a link. It should work now.
BobsYourUncle
Posted: 08/29/10 03:16pm Link  |  Print  |  Notify Moderator
Wow!
I have never seen a shackle fail like that before. It's like the bolt was yanked right out the end of the steel.
Gadget Guy
Calgary
Posted: 08/29/10 03:20pm Link  |  Print  |  Notify Moderator
Wear on the shackles is a common problem and not caused by loose bolts. The type of shackles that are used are not meant to be used on an RV unit that sees a lot of miles. They should be inspected regularly and changed every 6000 miles. A good upgrade is to change them over to a greaseable unit. They come with brass bushings and the side plates are made from at least 3/8" material. It is really to bad that RV manufactures use these light duty shackles to save a few dollars.
richfaa
Ohio
Posted: 08/29/10 03:33pm Link  |  Print  |  Notify Moderator
Same thing happened to us on our 06 Montana 3400. We never checked the shackle bolts for proper torque as required in the instruction manual and paid the price.
2013 Montana 3402 Big Sky. 08 Ford F-350 6.4L
Rvpapa
Alberta , Can.
Posted: 08/29/10 04:17pm Link  |  Print  |  Notify Moderator
That is normal for plastic bushings. The bolt seizes up in the spring eye and then reams out the shackle plate until it fails.
Art.
bstark
Ontario, Canada
Posted: 08/29/10 04:50pm Link  |  Print  |  Notify Moderator
Rvpapa nailed it! As the spring performs it's function with a seized bolt in one eye it causes the bolt to rotate slightly in the shackle plates thereby wearing it's way slowly through with every up and down cycle of the axle.
The other parts to inspect while you're under there is those center bolts of the 'dog-bone' equalizer beams. It's a little harder to do because you have to support the rig while your remove the beam from within the hanger but when you do you'll see those beams are developing vertically 'oval' holes.
A quality wet-kit with zerked bolts and bronze bushes is the answer for these ills.
Today is just the tomorrow you worried about yesterday!
C Schomer
Pueblo West, Co.
Posted: 08/29/10 05:23pm Link  |  Print  |  Notify Moderator
You sure got lucky, having parts that close - that would have been hard to fix with baling wire or duct tape! Craig
 > Broken Shackle
