RV.Net Open Roads Forum: Fifth-Wheels: Cable operated slides
 > Cable operated slides
Page of 7
oleglass
North Mississippi
Posted: 08/29/10 05:03pm Link  |  Print  |  Notify Moderator
We are looking to trade our Jayco TT in on a new 5er.
We have found a Durango D325SB that we like, it is a 2010 model
The salesman explained that the slides were operated by a combination of cables, chain and an electric motor.
Is this type of system trouble free, or is the rack and pinon system better?
As someone with a farming background, I do know the more moving parts, the greated the option for failure.
Does anyone on the forum have any experience with this type operating system.
We also found a Jayco eagle superlite (31.5 RLTS) that we liked, so what is the thought of the board on these choices?
We have had a TT for several years and are looking to upgrade, since I plan on retiring in about 3 years and we hope to be able to travel some.
Any input will be appreciated!!
Thanks!!
C Schomer
Pueblo West, Co.
Posted: 08/29/10 05:31pm Link  |  Print  |  Notify Moderator
I had a 5er with an elec. pump/hydraulic ram/cable operated slide and the slide mechanism was the only thing that was worth a damn on the whole RV! Craig
pcm1959
home
Posted: 08/29/10 05:54pm Link  |  Print  |  Notify Moderator
While I have had no experience with the cable systmes, I did look at how they work on the BAL website. They are becoming much more widely used - especially in units trying to reduce gross weights. The Montana High Country series have them and Heartlands are using them in many bedroom slides. In main level slide rooms, the need to cut holes in the I-beam frame is negated as well as the elimantion of the traditional slide room arms and exposed gearing, etc. Here is a link to the system: Pcm
http://norcoind.com/bal/products/oem/accuslide/index.shtml
move down the bottom of the link for a demo of the system.
* This post was edited 08/29/10 06:31pm by pcm1959 *
2013 Silverado 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
Mile High
CO
Posted: 08/29/10 07:15pm Link  |  Print  |  Notify Moderator
I noticed them too on the Montana High Country - and I believe Montana had to go to a cable system for the front living room model to keep the floor level down (bedroom slides have the ram under the bed).
I'm not sold on it after watching my Starcraft pop up self destruct more than once as a result of a frayed cable on the lift system. I also think they are a little unsightly to look at from the outside.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Randu
South Central Michigan
Posted: 08/29/10 07:27pm Link  |  Print  |  Notify Moderator
Open Range has been using the cable system since they started out about 4 years ago. Might do a search on "Open Range" and see what comments there are on the slide system. I don't recall reading about any problems. I actually think the idea has merit as top and bottom of slide are pulled evenly. Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
oleglass
North Mississippi
Posted: 08/29/10 07:44pm Link  |  Print  |  Notify Moderator
Thanks for the link, that is very clear how they work.
I do not feel like they will give much trouble after reading about them and watching the video..
Thanks
srkfb1
Chino, CA
Posted: 08/29/10 07:46pm Link  |  Print  |  Notify Moderator
Well that's news to me, ours is driven by gears, and it's an '09 Durango 35BHH, no chains there, it is electric motors I'd check that source, here's the web sightclick here
2009 Durango 355 BH
2007 Chevy Duramax Diesel
2005 Trailblazer-DW
2002 Grand Cherokee LTD
2003 Grandson Anthony
2006 Minature Schnauser-Dee Oh Gee
2008 Pickles Heinz 57
2009 Rusty Parsons Russell Terrier
steelpony5555
Copperas Cove Texas
Posted: 08/29/10 07:50pm Link  |  Print  |  Notify Moderator
They pull evenly and you don't have the big holes in the frame for rams and such. They have been used in the past on some high end units.
14 Cedar Creek Silverback 29IK
10 Dodge 3500 Dually Laramie 6.7 Diesel
14 Chrysler 300
07 Pearl White Ultra Classic (My new Baby)
Texas Boomers---Stop by for a Margie some time!
mayo30
Up here in the cold,cold north.
Posted: 08/29/10 09:40pm Link  |  Print  |  Notify Moderator
I had that on an Rvision Ts25ss and it was pure junk,holes in the rubber seals etc. never could get it to pull even and seal properly,but then the unit as a whole was less then fun,might have just been the manufacturer.Would never stay in adjustment or alignment,and constantly leaked.Haven't looked at anyone elses use or installation.
time2roll
Posted: 08/29/10 10:09pm Link  |  Print  |  Notify Moderator
No experience with cables except for the lid to my pop up trailer and they worked just fine. I would focus on the floorplan and assume the engineers have installed a good slide system.
675w Solar pictures back up
Page of 7
