RV.Net Open Roads Forum: Do You Leave Hot Water Heater On All The Time
 > Do You Leave Hot Water Heater On All The Time
1ed
Northern California
Posted: 08/31/10 10:35pm Link  |  Print  |  Notify Moderator
Just found out that I have to go outside to light the pilot light on the hot water heater and was wondering do most people just leave it on the entire time they are out or do you turn on and off.
I am use to the MH where I had a switch so just curious I know it doesn't use too much propane just curious.
chisnsamnbobnella
hamilton, oh
Posted: 08/31/10 10:44pm Link  |  Print  |  Notify Moderator
I have an electric water heater and I turn the switch off at night or when we go away for the while and leave it on when we are in. In your situation I would be motivated to turn it off to save gas and leave it on to save time.... not sure what I would. Sorry not much help I guess.
Sam the wife, Bob the me, Ella the baby girl and 3 Chihuahuas... Charro Shakira and Steve.
2010 Jayco Jay Feather EXP 23J
2007 Ford Explorer Sport Trac V8
ROBERTSUNRUS
Salem, Oregon
Posted: 08/31/10 10:52pm Link  |  Print  |  Notify Moderator
[emoticon] Hi, at first we left the water heater on all the time. I read where someone stated that parked next to someone else's RV, the water heater sounded like a blast furnace. In my trailer, my water heater is right under my head, in the bed, and I would hear it kick on and off during the night. Now we turn it on in the morning, turn it off after breakfast, turn it back on after dinner, and off before bed time. It doesn't use that much gas, but it isn't necessary to run it all the time and I sleep a bit better by not hearing it kick on and off at night.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
DesertHawk
Las Cruces, New Mexico
Posted: 08/31/10 10:59pm Link  |  Print  |  Notify Moderator
Normally, I either turn it off after using it, or I turn it to the pilot setting. It keeps the pilot light on but will not turn on the blast furnace. The pilot will keep the water hot and ready to go next morning.
">DesertHawk- Las Cruces, NM USA
*2015 Lance 1985~Casita de Campo~23' 4" Tongue to Bumper, Dinette Slide
160 watt Solar Panel/GoPower! Solar Controller
*2009 White Ford F-150 Reg. Cab
Long Bed with A.R.E. Molded Fiberglass Topper
*Previously~ 2005 16' Scamp
usmc616
Orange County, New York
Posted: 08/31/10 11:20pm Link  |  Print  |  Notify Moderator
My second TT had a manual lighting pilot on the water heater. My current one has an electric ignition. I always leave the hotwater heater on. I have 2 30 lbs propane tanks on my TT and prefer to have hot water whenever I want it and not need to wait for it to warm up.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.">
mosseater
Dillsburg, PA
Posted: 08/31/10 11:29pm Link  |  Print  |  Notify Moderator
We normally turn on the electric element when we get settled in to a new campground. That way we have some hot water if we need to do dishes or wash up, etc. We only turn the gas on when we are going to run bigger quantities of hot water for showers or a lot of dishes. In that case we run both. It stays pretty hot for a long time even if you turn it off. If you have the gas powered up and aren't using much hot water, it isn't going to cycle that often anyhow. If we are going to be away for a while, we turn both the water pump and the heater off just in case.
Sunset Creek 298 BH
JKL
Edmonton, Alberta
Posted: 08/31/10 11:44pm Link  |  Print  |  Notify Moderator
My first two trailers had hot water heaters that used a pilot, my last three have been electric start. They have all stayed on from the time we set up in the site to the time we break camp.
1993 Cobra Sierra 27 foot triple bunk
2006 F150 SuperCrew XLT/XTR,5.4,4x4,6.5' box,3.73 axle
Retired Phone Man
Covington, Louisiana
Posted: 08/31/10 11:45pm Link  |  Print  |  Notify Moderator
I have the manual gas heater also. I normally turn it to pilot when its not needed. Usually keeps the water hot enough to wash hands and short usage. Turn it to on before shower or dish washing time and then back to pilot. Turn it off when under way.
Jim [emoticon]
2007 Toyota Tundra SR5 Double Cab with 5.7L V8 and Tow Package.
2007 Gulf Stream Ameri-Lite 21MB
Peaches - Lhasa Apso/Mut Mix
BobsYourUncle
Calgary Alberta Canada
Posted: 08/31/10 11:53pm Link  |  Print  |  Notify Moderator
I turn mine on at home while loading up and prepping to leave for a trip and I don't turn it off until I get back home again, except for fueling up on the road.
Mine is manual, so the pilot light almost always blows out when I hit the highway. I do relight it when I get to my destination and leave it on the whole time. When I want hot water, I want it to be there. I can't be bothered to turn it off and on constantly. Not worth the hassle to me.
I don't concern myself with a little extra propane burned to keep it hot. For me it is a non issue. If I have to worry about 13 cents worth of propane, I may as well sell the RV.
Duramax / Allison
Fire Red
1997 Triple E Topaz 27' Bunkhouse TT
tvman44
Southwest Louisiana
Posted: 09/01/10 12:08am Link  |  Print  |  Notify Moderator
If on propane I turn off when not needed.
Papa Bob
Husky 16K hitch, Tekonsha P3,
