RV.Net Open Roads Forum: Travel Trailers: Buzzing Noise Through Speakers When Using Inverter
 > Buzzing Noise Through Speakers When Using Inverter
OBSPowerstroke
Portland, OR
Posted: 09/12/10 12:24pm Link  |  Print  |  Notify Moderator
While playing around with the laptop and television in the trailer this morning, I noticed I get a real loud buzzing noise through the speakers in the trailer any time I try to run either the TV and/or laptop off the inverter with the audio being output to the trailer stereo.
If I turn off the trailer stereo and run the audio strictly through the TV, there is no buzzing noise, and the inverter powers both the TV and laptop just fine. I can run the TV and laptop directly off the A/C circuit in the trailer and output the audio to the stereo with no noise issues. I only get the buzzing when attempting to incorporate the inverter.
Below is the equipment I'm using:
Trailer Stereo: Jensen AWM970
Inverter: VR-3 175 watt max output
Television: Vizio 22" LED M220MV
Laptop: HP Pavilion dv8
Any suggestions for solving the buzzing noise through the stereo? At least I know my inverter will power everything just fine when I strictly have battery power, however it would be nice to output the audio to the stereo speakers...
Thanks in advance!
Josh
'16 Ford F350
'11 Komfort Resort 240RK
Portland, OR
cmartin7143
ILL
Posted: 09/12/10 12:54pm Link  |  Print  |  Notify Moderator
I am no electronic wiz but the buzz is the inverter at work. Its much like a freq drive used in buildings its creating dirty power into the 12vdc system. try radio shack and pick up a automotive line filter and install it in the power feed to the Jensen. it should be able to smooth the power and stop the noise. its cheap and easy place to start. Good luck!
2chiefsRus
USA Somewhere
Posted: 09/12/10 12:55pm Link  |  Print  |  Notify Moderator
We used to have noise in our TV and microwave Clock before we replaced our modified sine wave inverter with a pure sine wave inverter. Fine now.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
OBSPowerstroke
Portland, OR
Posted: 09/12/10 01:03pm Link  |  Print  |  Notify Moderator
My current inverter is a Costco special MSW, and an upgraded, permanently installed inverter is definitely on my list as an eventual upgrade, but I'm planning on getting by with what I have at the moment until my wallet cools down a bit from buying and outfitting the new trailer. [emoticon]
colliehauler
Mc Pherson KS USA
Posted: 09/12/10 03:21pm Link  |  Print  |  Notify Moderator
Modified Sine wave dirty power and hard on electronics. Pure sine wave clean power.
Rick From Sequim
Sequim, WA
Posted: 09/12/10 10:30pm Link  |  Print  |  Notify Moderator
Buzz is because your converter produces a modified sine wave (as in not pure clean alternating current). A more expensive inverter solves the problem.
Rick ">
& wife Loie & Kodi Dog (blk male std poodle)
2011 GMC Sierra & 2005 25' Bigfoot RQ
OBSPowerstroke
Portland, OR
Posted: 09/12/10 10:48pm Link  |  Print  |  Notify Moderator
I figured the likely culprit is my cheap inverter, but it seems odd that the audio is crystal clear through the TV on the inverter but not even discernable through the trailer stereo and speakers. If the inverter was that bad, wouldn't I get the same interference off the TV audio?
I don't mind spending the money for a good inverter, but I want to make sure I won't be blowing a ton of cash just to have the same problem.
mobeewan
Hampton, Va
Posted: 09/13/10 12:11am Link  |  Print  |  Notify Moderator
The tv probably has circuitry in it that smooth out the RFI created by the inverter.
redwake
Visalia, CA
Posted: 09/14/10 08:23am Link  |  Print  |  Notify Moderator
change inverter or buy isolator/filter radio shack will have a solution either way.. look for the older guy that's worked there for a while he will help you out more than the kid selling the cell phones.
TT: 08 Monterey 27 PT by Extreme RV
TV: 05 Eddie Bauer Expedition w/5.4L 3.31 Gears ">
Hitched with a Husky WD & SC.
Powered by Champion 3500
N8GS
West Michigan
Posted: 09/14/10 06:56pm Link  |  Print  |  Notify Moderator
Yes, changing to a pure sign wave inverter will solve your problem. I have 3 Samlex inverters. I have a 2000 watt mounted in mt FW to run the Micriwave, TV and computer. I keep a 150 watt in the truck to power the computer and cell phone chargers. The 600 watt unit is in the semi.
Check out DonRowe.com, he has good prices and you can call him and get good honest advice.
Ham radio 73's from Gale N8GS
2009 GMC 2500HD Ext cab, LB 4x4 Duramax
2015 Grand Design Reflection 337RLS Pin wt.2900#
B&W companion
2 Honda EU2000i
400 Ah LiFePO4 batteries + 470W of solar w/ Outback FM-60 CC
Samlex 2000w PSW inverter
