RV.Net Open Roads Forum: Slide out Construction
taylorga
newcastle, wyoming
Posted: 09/16/10 07:23am Link  |  Print  |  Notify Moderator
Does anybody have or know where I might find a construction design diagram for the slide out design where the wall and floor connect together. Mine is seperating and I need to understand how it is constructed so I can repair it.
mpfireman
Cook County Il
Posted: 09/16/10 07:46am Link  |  Print  |  Notify Moderator
My first option would be to visit any RV dealership that sells your brand of trailer. Explain your problem, it might be a simple adjustment, or might require a more timely repair. The dealership could also provide you with the TX number of the factory.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
azimmey1
Baltimore
Posted: 09/20/10 01:58pm Link  |  Print  |  Notify Moderator
Mine failed also exactly like yours, no sign just crack. I e-mailed Thor Ind. (Dutchman), but they pretty much refuse to help.
Do yourself a favor and buy a slide topper that goes beyond your room and it probably will never happen again.
The gent with the pictures helps but kinda leary to fix myself.
Fortunaley Dutchman still sells the one piece floor for my 16' slide out. Tells you they knew they had a problem if they still carry the floor for a 10 year old unit.
Old Blue
New York USA
Posted: 09/18/10 05:34pm Link  |  Print  |  Notify Moderator
www.norcoind.com might help you..there is a bunch of information
Bill
Bill
36 Holiday Rambler
Harley Rider
mister_d
Southeast, MI - hardly qualified to be a
Posted: 09/17/10 09:01pm Link  |  Print  |  Notify Moderator
This happened to Chuck_S over in the HTT section. Check to see what he's found - it was recent so you shouldn't have to dig.
Our Adventures
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
Me '77 DW '78
DD '04 DS '07
BarneyS
S.E. Lower Michigan
Posted: 09/18/10 07:51am Link  |  Print  |  Notify Moderator
The following link by member JBarca will probably help you out. He rebuilt the whole floor of his slide and documented the project with many pictures and good comments. It is quite a long thread but should give you much needed information. Good luck.
JBarca's slide rebuild project.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
