RV.Net Open Roads Forum: Class C Motorhomes: Wind Deflectors for Wind Noise
 > Wind Deflectors for Wind Noise
cccougar
Cherry Hill
Posted: 09/28/10 08:37pm Link  |  Print  |  Notify Moderator
Just out of curiosity- is there a product out there for a wind deflector on the side of the MH? We have a real bad whistling/cricket sound coming from the outside and the DW says it sounds like its from the awning bracket. Is it possible the wind is going through the little openings of this bracket and making this noise? Just curious.
ronfisherman
SE Michigan
Posted: 09/29/10 03:50am Link  |  Print  |  Notify Moderator
Could be the bracket. Try putting some duct or masking tape over area to change air flow. Take MH for a ride and see if it stops noise.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 09/29/10 08:27am Link  |  Print  |  Notify Moderator
If your windows have small horizontal slits at the bottom for drainage try placing a piec of tape over them that extends a tiny bit past the opening. Don't press the tape into the hole to plug the hole. Water can still escape but the wind noise on my mh is gone. Mine actually came with some plastic inserts that did not stop the noise. The black tape or clear packing tape will allow the frame color to show. Replacement about every 6-12 months is necessary.
I also ran some 3M plastic tape that is about 1.5 inches wide down the hinge area of the entry door. This too helped.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
AstroRig57
near Tehachapi, CA
Posted: 09/29/10 10:26am Link  |  Print  |  Notify Moderator
Air Tab's. Noticed these on Moderator Westronic's profile. I have no experience with them, I'm assuming he does. Ask??
2005 Winnebago Sightseer WFD30B "rigged for night" with red LED lighting for night adapted vision.
Do you remember when the sky was dark, and the stars were bright?
The International Dark-Sky Association
American by birth...Scottish by the Grace Of God.
