RV.Net Open Roads Forum: Class A Motorhomes: Peeling clearcoat...what to do?
 > Peeling clearcoat...what to do?
bowl300
So Cal
Posted: 09/29/10 12:59pm Link  |  Print  |  Notify Moderator
The clear coat on almost our entire roofline is peeling. Any suggestions on what to use to buff and seal it? Don't want to use wrong buffer/sandpaper to smooth it and take off the full body paint underneath.
I've read that the 2k spraymax urethane aerosol clear coat is a good product to use.
Also, would need to buy a buffer, any thoughts on a decent one?
Thanks for your input.
2011 Tiffin Phaeton - 40QBH
2005 Saturn Vue V6 Toad
Ed & Doreen
Lily & Bailey (Our Siberian Huskies)
Maggie & Elvis (King Charles Cavalier Spaniels-Our Love Sponges
MartinDYN
SoCal
Posted: 09/29/10 01:45pm Link  |  Print  |  Notify Moderator
I have a similar occurence on the front and rear caps on the top. I am going to sand/feather the edge of the intact clear coat and try to spray some clear coat to the damaged area.
I will talk to the local auto paint store and see what they recommend to use.
Shouldn't be too hard.
'70 Jeep CJ5 + Sears Tent(Sold)
'70 Jeep + '63 Field and Stream Trailer(Sold)
'86 Ford F250 + Lance Camper(Sold)
'73 Dodge Sportscoach Class A(Sold)
'86 GM Eleganza 31' Class A(Sold)
'99 Suburban + '74 AS Landyacht(Sold)
'97 Damon Intruder 35' DP CAT
zmotorsports
Utah
To do it properly so it will last at least as long as the original, sand it down and reapply. It is time consuming and messy. I repainted the top of the roofline as well as both front and rear end caps on our 1991 Beaver Contessa about 10 years ago and it took the better part of a week of evenings and one weekend. It still looks good last time I saw the coach (about six months ago).
I need to do our Dynasty next year. It is starting to do the same thing. Not looking forward to it. Mike.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
Paul G.
SW, MN
Posted: 09/29/10 02:06pm Link  |  Print  |  Notify Moderator
Here is what this guy did.
chastho
arkansas
Posted: 09/29/10 04:45pm Link  |  Print  |  Notify Moderator
I had the same problem on the top of my front cap, I stopped in Red Bay,AL and had Bruce Deaton redo it. He repainted the top instead of just redoing the clear coat, perfect match on the paint and blended in so you can't tell where he painted.
RayChez
Barstow, Ca. USA
Posted: 09/29/10 08:37pm Link  |  Print  |  Notify Moderator
I think I would take my coach to a good paint shop and show them what is happening to the clear coat and get some advice from the professionals.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
JFC
Northern California
Posted: 09/30/10 10:43pm Link  |  Print  |  Notify Moderator
In 2005 I had the clear coat on the rear cap of my HR Ambassador peeling. It was so bad, it literaly washed off in sheets when I washed the coach. Monaco was no help. I finally had the rear cap striped, re-painted and new clear coat applied by a truck painting facility. Stil looked great whenwe traded it in 2007, and cost about $1200.
deandec
Northern CA
Posted: 09/30/10 12:42pm Link  |  Print  |  Notify Moderator
I had the brow clearcoat removed, painted to match, and recleared about 7 years ago when the rig was 9 years old. It still looks good.
Since then, I have sanded with 1500 grit wet sandpaper the edges of the peeled areas and then used the 2K rattle can to spray three coats of Clear. Not perfect but not visible from the ground. Durability is yet to be seen.
All of my peeling areas are originally clearcoat over gelcoat. The clearcoat over paint has yet to peel, knock on wood!
Dean
95 CC Magna, Jeep GC
Goodturn
Ontario Canada
Posted: 09/30/10 01:19pm Link  |  Print  |  Notify Moderator
My 07 Mountain Aire is doing the same thing. I agree with RayChez. I'm looking for a good paint shop while we're in Florida this winter.
rjcalif
Garlic Capital of the World - Gilroy, CA
Posted: 09/29/10 05:30pm Link  |  Print  |  Notify Moderator
I did my own front cap and an area on the side of the coach that had a nasty tree branch scratch. I smoothed the edges with 3M paint prep pads (green) and then used Dupli-Color Clear Acrylic Top Coat in a rattle can and it looks great. Follow the instructions on number of coats and wait time between coats and you should be fine.
RJ
2000 American Eagle 40DS and 2000 Suburban 2500 4x4, the super toad
