RV.Net Open Roads Forum: Class A Motorhomes: Engine wont start
 > Engine wont start
joeone2000
Joliet ILL
Posted: 10/05/10 09:33am Link  |  Print  |  Notify Moderator
I was running engine to charge bat.I tried to start gen.It died.It does nothing.I pushed aux bat and it starts until let the button go.It is Southwind Storm 99 with 6.8 v10 Ford.Help
pianotuna
Regina, SK, Canada
Posted: 10/05/10 09:41am Link  |  Print  |  Notify Moderator
Hi,
Check the starter battery and see if it is dead as a dodo. Check the alternator for output.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
Executive
Posted: 10/05/10 11:43am Link  |  Print  |  Notify Moderator
Your batteries are KAPUT!...get the hydrometer out, test them all, decide if any are worth saving, then time to go shopping...IMHO, once one dies, I replace them all......Dennis
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Smitty77
OnDRoad
Posted: 10/05/10 01:27pm Link  |  Print  |  Notify Moderator
If the Battery should be OK, then check to see if you are putting out a charge while running the engine... Could have run until it drained the battery?
Smitty
joeone2000
Joliet ILL
Posted: 10/05/10 03:00pm Link  |  Print  |  Notify Moderator
The bat is charged.The aux bat will start the motor but it dies when i let the button go.I can,t run the engine to check anything.
jaychat2003
CA
Posted: 10/06/10 04:02am Link  |  Print  |  Notify Moderator
Check your alternator, output may be low or none at all.
J
Captain_Happy
Pahrump, Nevada
Posted: 10/06/10 05:17am Link  |  Print  |  Notify Moderator
I beleive the OP is refering to the generator start switch. Sounds like when he pushes the switch to start generator it starts, but when he takes his finger off the switch, the generator dies. Does that sound right? It sounds like the generator start switch is the problem, not the batteries. Just my 2 cents.
joeone2000
Joliet ILL
Posted: 10/06/10 06:59am Link  |  Print  |  Notify Moderator
The aux button to start the engine is what i was talking about.The engine will start and then die when i let it go.The motor died when i tried to start gen.Now it wont do nothing when i try to start motor.But it will start with aux start and then die when i let go of button.
427435
Rochester, Mn
Posted: 10/06/10 08:30am Link  |  Print  |  Notify Moderator
I believe you're talking about the MH engine-----not the generator engine. I also think that your chassis battery is dead and that, possibly, the alternator is not working on your MH engine. Start it again using the auxiliary battery switch and keep that switch held down for a couple of minutes while watching your voltmeter. The voltmeter, before hitting the aux switch, should show a low (or no) voltage when you turn the key on. When you hit the aux switch, it should jump up to around 10-12 volts. Once the MH engine is running, the voltmeter should read 13-14 volts. If the voltage doesn't go up after a few minutes of running, something is wrong with the alternator or connections.
Come to think of it, cleaning the connections on the chassis battery would be a good idea also.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
joeone2000
Joliet ILL
Posted: 10/07/10 02:41pm Link  |  Print  |  Notify Moderator
Thanks for the help.It was the bat.I charaged it 12.3,but as soon i put load it was dead. Had the bat checked and replaced.
 > Engine wont start
