Open Roads Forum
Print  |  Close
Topic: Water Pump Won't Shut Off
Posted By: Mr. Sandman on 10/05/10 10:40am
I did a search and couldn't find much so here's my question; last trip out we stayed in both full hookup and dry campgrounds (WW LE3505). In the dry campgrounds the water pump worked fine and was still working fine when I put the trailer in storage. I picked it up yesterday for an upcoming trip and the water pump runs continuously when turned on at the switch and no faucets turned on. The tank is full and there aren't any leaks or broken lines anywhere. Any ideas?
Tow Vehicle - 2004 Ford F350 PSD 4x4
Hauler - Sold/None
Toys - 2009 Polaris RZR LE, 1985 ATC 250R,
2009 Raptor 700, 2003 Raptor 80,
Posted By: nayther on 10/05/10 11:06am
Have you bled all the fixtures? Trapped air will cause this. If all fixtures are bled (including outdoor shower) and there are no leaks you might just adjust the pressure switch a little bit, there's a screw on the end of the pump, counterclockwise lowers the pressure.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Posted By: mapguy on 10/05/10 01:54pm
Do you get running water when a faucet is open?
1. Inlet check valve not working right so pump has lost its prime / won't pull water to prime.
2. Pressure switch malfunction. No high limit cut-out.
Posted By: Pipeman on 10/05/10 12:49pm
Mine will do that until pressure is built up enough in the lines. It then stops by it's lonesome. Have you waited to see if it stops after a while? You could try opening a tap or two to bleed off some trapped air also....remember your toilet also. Good luck.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
Posted By: gpshemi on 10/05/10 01:56pm
Filling the hot water tank?
GPSHEMI
06' 3500 Dodge Ram Megacab 4x4 w/ bombed 5.9L
18K Pullrite SuperGlide w/super rails
2010 Heartland Cyclone 3612
Posted By: nayther on 10/05/10 02:33pm
Yea, be sure you're bleeding both hot and cold. If the water heater was drained it will take some time to bleed the air.
Posted By: IOWASTROKER on 10/05/10 06:52pm
Rather than letting the 12=volt water pump fill your water heater, connect to the city inlet first, run in and bleed off every fixture, then fill your holding tank, then turn on water pump. Saves alot of time AND your pump.[emoticon])))
Posted By: carlacee on 10/05/10 09:55pm
Does anyone know what the stock pump is?
2005 Dodge RAM 3500 CTD Q/C 4X4 DRW NV5600 - 3.73
Posted By: Mr. Sandman on 10/05/10 08:14pm
shawnct450r wrote:
When you say it runs continuously, how long did you let it go for? I am curious, as I have a WW also. Haven't had this problem, but subscribing to possibly learn something.
I let it run for about a minute and a half while I searched for leaking lines before I shut it off. I'll let you know what I find when once the hot water heater is full and all the lines are bled.
Posted By: carlacee on 10/05/10 09:22pm
what kind (manufacturer) of pump is it? Shurflo? what model?
Posted By: Mr. Sandman on 10/05/10 09:51pm
I have no idea as I haven't crawled into the cabinet to look at it and hopefully won't have to.
* This post was edited 10/05/10 10:25pm by Mr. Sandman *
Posted By: shawnct450r on 10/05/10 10:58pm
I am picking up the trailer tomorrow AM to get the main AC replaced. I'll look and get the spec's for my unit. Should be the WW standard.
04 F250 FX4 Diesel
06 WW LE3305
06 Honda TRX450R (CT Racing)
04 Suzuki LTZ250 (Son's stunt machine)
06 Suzuki LT50
05 Honda VFR800A
Posted By: Mr. Sandman on 10/05/10 03:19pm
Thanks for the info guys. I do get water when the pump is running but I'll let it run a while (hot and cold) as I did drain the hot water heater to replace the drain plug that was leaking before the trailer went back to storage. Hopefully that's all it is. Thanks again!
Posted By: shawnct450r on 10/05/10 06:04pm
Posted By: Mr. Sandman on 10/08/10 08:41am
Once the water heater was refilled and all the lines bled the pump shuts off like it's supposed to. Thanks for all the info guys...problem solved!
Posted By: gpshemi on 10/08/10 08:52am
No sweat.
Posted By: MaxAZ on 10/07/10 09:53pm
When you fill your tanks after draining the water heater you will usually get a large air pocket built up in the water heater tank. What I usually do is hook up the hose to the camper directly and turn it on. Then open up a hot water faucet valve and wait until water comes out evenly. That's a quick and easy way to bleed that tank and then you can disconnect the hose and switch it over to the water pump. I believe it's important to get all the air out of the hot water tank before you heat the water up so you're heating water and not making steam.
20008 Chevy 2500 HD Duramax pulling a 2008 Rampage 281 Toyhauler.
Posted By: Dieselgem on 10/06/10 07:00am
When I leave my switch which controls if the water is going into the holding tanks or city water in the holding tank position and then dry camp my pump will not shut off once I use the water. I never thought about it, just turned the lever to the city side and it works like normal. I just figured it should have been returned to that position if you were not filling the holding tanks. Maybe yours is the same.
2013 Entegra Aspire DEQ
2003 FLSTS
2003 FLSTC (Wife's)
Posted By: code3run on 10/06/10 02:46am
This may have already been said but turn the pump on and then bleed the lines from your outside drains on both hot and cold side. That gets the air out quick and pump shuts off. Cant think what you call those drain lines outside the trailer for winterizing. Mine are two hose with valves,one hot water and one cold water....
2008 ATTITUDE 21AK
2007 Dodge Ram 1500 hemi 5.7 lit
07 Yamaha ttr 125
01 Yamaha yz 125
2 boys 13 and 16
a wife
a dog named Dusty
Print  |  Close
