RV.Net Open Roads Forum: Electronic Ignition for Stovetop (w/pics)
 > Electronic Ignition for Stovetop (w/pics)
Page of 14
12thgenusa
Lakewood, Colorado
Posted: 10/30/10 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I finally got tired enough of the piezoelectric igniter on my Atwood stovetop that I decided to replace it with a battery-powered igniter unit. You know what I’m talking about. You twist the knob; bam, bam, bam . . . bam, bam, bam and sometimes the burner lights and sometimes not.
I removed the old igniter and took some measurement to determine the available real estate. I found a replacement electronic igniter for Charbroil grills from Home Depot for $30 that looked promising.
The hole for the original igniter was 5/8” and the new one requires 7/8”. If you have a unibit step drill, that would work nice. But since I don’t and didn’t want to spend the $$ I used a stone grinder bit and “hogged” the hole out to 7/8. You need to “cheat” the hole slightly up and to the left for a little more clearance for the igniter.
Pull the wires off the old igniter and slide them on to the new, order does not matter. Even though the old igniter has round pins and the new has spade pins, the terminals slide on with a tight fit and work fine. Due to the higher voltage of this unit I saw occasional flashover between the terminals when it was activated. I solved that by adding a second layer of heat shrink over the terminals.
The new igniter has four terminals and since the stovetop only has three burners, that left one to add a sparker for the oven pilot light. The new unit comes with spare 37” and 32” igniter wires. I joined the two together and they were long enough to reach across the stovetop, and follow the oven control plumbing down into the oven. The longer wire looks like it has a high-temp coating, but I also wrapped the part that is actually in the oven with high-temp fiberglass tape. I needed a sparker so I removed the one from my gas grill side burner, which I never use anyway. After removing the burner assembly from the oven, I “guesstimated” the location for the sparker and drilled a 7/16” hole in the pilot support plate. Once the sparker was in place, I reinstalled the burner assembly. The sparker electrode had to be “tweaked” slightly to get a reliable spark to the outlet end of the pilot light tube.
If you don’t add the oven igniter, you need to install one of the supplied wires on the fourth terminal and coil and stow the wire so that it won’t short to the stove. If you don’t do this, the bare terminal on the igniter will flashover to the others.
After installing the single AA battery and turning on the gas, it was time for a test run.
Aaaahh . . . The stovetop burners light almost instantly, quietly and reliably. The electronic ignition sparks about six times per second for as long as you hold the button as opposed to three sparks per half-revolution of the knob on the old one.
The oven pilot lights nicely. I’ve found that if you turn the oven knob to “pilot” and hold it for about 10 seconds and then push the igniter button, it will light almost instantly. I was a little concerned about the wire in the oven, so I heated the oven to 500 degrees for a test. Everything looks good and smoke check passed.
DW is HAPPY, and you know what that means . . .
Before
Old Piezoelectric Igniter
New Electronic Igniter
Oven Pilot Light Sparker Installation
After
Dave & Gean
2007 Tundra DC 4X4 5.7
2009 Cougar 245RKS
370 watts ET solar
Rogue 3024 MPPT controller
440 Ah battery bank
ProWatt 2000 inverter
ccrain2851
Palmyra, IN
Posted: 10/30/10 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
wow.... very impressive.
C Crain
a Wife, 2 Kid, Dog & 2 Horses
'01 F250 SC LB 7.3 4x4
'10 Springdale 267BHSSR hooked to an Equal-i-zer
'01 Feather Lite Trailer G/N, 3 horse slant w/ living area hooked to a B&W turnover ball
Alpenliter
Fulltimer: Wherever we are!
Posted: 10/30/10 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Dave, I have the same stove and I'm getting tired of having to get down on my hands and knees to light the oven whenever DW wants to use it. Your clear pictures and descriptions have given me the nudge I need to get the job done. Thanks very much for all your information and pictures!
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
Normk
Canada's Wet Coast
Fantastic! I'm on this like a sled dog on a pork chop!
Thanks hugely!
ernestfortier
Palmdale, Calif.
Posted: 10/30/10 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
Great pictures great information. Thanks. I'll have to look into doing this myself. As soon as I get done procrastinating. I hope it will be soon.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
w6pea
Posted: 10/30/10 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
I second this post. Great pictures good job.
Remember "Without Trucker's America Stops"
"Buy American Made Only!"
It's too late to save your shoes..roll up your pant legs
"When all else fails..Amateur Radio"
I need more Coffee & Old Bushmills
If We Can't Haul It..You Don't Need It. Motor-T
Semper Fi
ronfisherman
SE Michigan
Posted: 10/31/10 03:14am Link  |  Quote  |  Print  |  Notify Moderator
I was going to replace my Suburban stove top because it did not have piezoelectric ignition. This looks like a much better plan and a lot less work. Thanks for the post.
Kodiak Chassis Class C Forum
LarryJM
NoVa
Posted: 10/31/10 03:21am Link  |  Quote  |  Print  |  Notify Moderator
Well all I can say is that my Atwood has worked great for over 3 years and have seen no need to modify it. I really like the no pilot lit burners.
Larry
* This post was edited 10/31/10 07:16am by an administrator/moderator *
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
LAdams
Northern Illinois
Posted: 10/31/10 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Great Mod and nicely done Dave I'll consider this one for my rig if for no other reason having to sit on the floor to light the stove pilot
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
Jerry9n
SE Michigan
Posted: 10/31/10 11:03am Link  |  Quote  |  Print  |  Notify Moderator
I don't have an oven, but got tired of lighting burners with a lighter. You turn the burner down too far and out it goes. Got a kit from Walmart for grills and bought another electrode on line.
Only problem I had was where to put the ignitor module. Ended up in the closet wall next to the stove. Works well.
You can kind of see the little electrode in the back of the burner.
Pushbutton mounted in a box on the closet wall. Wires run directly from box into stove cavity.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
Page of 14
