Open Roads Forum
Print  |  Close
Topic: Why 20 Pound Maximum Tank for Big Buddy?
Posted By: 67Airstreamer on 11/01/10 07:50am
My Big Buddy catalytic heater specifies a 20 pound maximum propane gas cylinder size.
I would like to use 30 pound and 40 pound tanks, or perhaps even a 100 pound size.
Why would there be a restriction for the heater?.
Surely it's not because of any gas pressure difference, but what else could it be?
Anyone know?
Posted By: Rob's on 11/01/10 08:05am
Size of cylinder makes no difference. Be sure you have proper connections and a regulator with 11" W.C.. Test all connections with soap.
Rob
RV Tech
Posted By: SWD on 11/01/10 08:19am
X2
Posted By: JesLookin on 11/01/10 08:35am
The 20 pounder is probably less likely to tip over, than the taller 30 or 40 pounders.
2013 Arctic Fox 27-5L
2014 Ram 3500 6.7L CTD, Crew Cab
Posted By: dbbls on 11/01/10 09:01am
I have been using a 30# for years and there is no problem.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Posted By: bill h on 11/01/10 09:08am
Does the manual have a phone number? It would be interesting to hear it from them.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
Posted By: CptnBG on 11/01/10 09:15am
SWD wrote:
X2
The Buddy heater already has a regulator built in, no additional regulator needed.
'03 2500HD CrewCab SB 6.0 Gas 4x4
'04 Northstar Laredo SC
Bilsteins 5100
2014 1500 Silverado 5.3 Double Cab
1951 Chevy 3100
Formally OBXcamper
Posted By: robatthelake on 11/01/10 09:30am
They are likely just complying with some liability issue, or simply writing their literature to cover the most commonly used Tank size!
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
Posted By: ryanallie1 on 11/01/10 09:34am
Hi All.
I can almost bet you they recommend a 20 lb'er, becasue anything smaller would be used up very quicky. The Big "Buddy" Mr Heater uses two 1 lb Propane Bottles. Or they recommend using a 20lb'er as it eats up Propne pretty quickly, compaired to its smaller brother, the Mr Heater "Buddy" Heater that only uses 1, 1 lb Propane Bottle or a 20 lb'er Propane Tank. Any size you can hook-up to will work just fine. Good Luck. Happy Travels. Dan & Jill
1998-34 ft Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
Posted By: randallb on 11/01/10 09:35am
They have most likely been sued when a large cylinder tipped over and pulled the heater with it. Most restrictions placed on products are directly tied to a legally decided liability issue or on advice from the corporate attorneys. You will also find that the hose will not be long enough to reach the valve on taller vertical tanks. This is a cost versus profit issue.
Randy
Posted By: CptnBG on 11/01/10 09:46am
You can get up to a 12' hose (filter recommended). I use a 12 footer with a 5 lb bottle. I'm also curious why the 20 lb max.
Posted By: Broccoli1 on 11/01/10 10:17am
It is because it is a Portable Heater and they only Certify it for the 20lbs use as "Portable"- to certify it for larger Tanks they have to pay for another certification process but it can be used on larger Tanks and as was mentioned anything over 20lbs isn't really as portable[emoticon]
Mr. Heater, INC., 4560 W. 160TH ST., CLEVELAND, OHIO 44135 • 216-916-3000
It implies this in the warning
"IT MAY ALSO BE OPERATED WITH (1) F271802 HOSE ASSEMBLY CONNECTED TO A REGULATED (11” W.C.) PROPANE SOURCE OR (1) F271803 HOSE ASSEMBLY WITH 11” REGULATOR WITH ACME NUT.
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rhino 660- 1980 Cobalt 18DV
CRF 50 & CRF 70
"Shoot, I'm the world's best backwards driver!"
Posted By: CptnBG on 11/01/10 10:50am
That makes sense about the portability but the regulated supply is still a bit confusing. From page 3 of the manual, " GAS PRESSURE AT HEATER IS REGULATED AND FIXED AT 11” W.C. WHEN USING A REMOTE HOSE CONNECTION
TO HEATER REGULATOR(S), DO NOT REGULATE OR REDUCE PROPANE TANK SUPPLY PRESSURE TO HEATER."
It seems the regulated supply is IF you use a quick disconnect hose ??
Big Buddy Manual
Posted By: 67Airstreamer on 11/04/10 08:39am
Thanks for the advice guys. It seems the Big Buddy statement about the 20-pound tank maximum relates to some obscure reasoning. It's too bad manufacturers don't explain why they put such things in their instructions. In any case, I can't see why a larger tank would be inappropriate.
OBXCamper, although the wording is typically confusing, I think they should be saying a remote hose possbily could be connected to a regulated supply, which would not good because the heater already has a built-in regulator. So using two regulators in line would provide inappropriate pressure to the heater. This seems to conflict with other statements they use.
In any case, using a one-pound propane bottle on the heater (ie no remote hose is used) provides the proper pressure since there would be no possibility of a second regulator.
Posted By: CptnBG on 11/04/10 09:42am
Yes it is confusing. I did some more reading and found this link. clicky
Scroll down a little and you can see where they removed the factory regulator to plumb in to the house propane (downstream from the regulator). Then you can use the quick connect type hose.
I do like you and use a standalone tank and leave the factory regulator in.
Posted By: letsrun on 11/08/10 01:06pm
I just received an e-mail from Mr Heater:
My Question:
Model Number : MH18B - Buddy, Big
The instructions say I can use my Big Buddy in a
recreational enclosure (RV) but with a maximum cylinder size of 20
pounds. Why can't I use the 30 pound RV cylinder? The 30 pound cylinder has threads the same as the 20 pound cylinder.
Thanks
Jim
Mr Heater's response:
Jim,
You can actually use up to a 40# tank.
Thank you,
Bill Sisley
Technical Service Manager
Posted By: javaseuf on 11/08/10 01:29pm
Re. the Big Buddy...................
This model has a regulator after the two fittings that you screw the one-pound bottles to. If you use a bulk tank connected to one of these fittings, it can't be regulated at the tank.
The Big Buddy also has a non-regulated quick-disconnect fitting designed to be used from a regulated gas supply such as a tap off of your already regulated RV propane system.
The smaller Buddy heater doesn't have the built-in non-regulated quick disconnect fitting so the unregulated bulk tank hose is connected from the tank to the fitting that the bottle screws into with NO regulator at the tank.
Posted By: letsrun on 11/08/10 03:24pm
Steve,
Thanks for the input.
I'm looking at the Big Buddy Manual. This manual is for an older model than the one I just bought. The older one has a regulator in the middle of the unit that regulates both inputs. My unit has two regulators, one on each side of the unit; one for each input. Regardless, the input to this unit is regulated.
Mr. Heater's manual states, "you can use a 20 pound tank (maximum)." My question was: "why you can use a 20 pound tank and not a larger one, 30 pound for example?" Mr. Heater's response was, "that I can use up to a 40# tank."
Jim
* This post was last edited 11/08/10 08:05pm by letsrun *
Posted By: javaseuf on 11/08/10 08:06pm
letsrun wrote:
Steve,
Are you saying I can't?
No, not at all. I was just saying that on the new models with the quick-disconnect, your supply needs to be regulated when connecting to the quick disconnect. You can use a bulk tank with the QD fitting BUT your tank will need to have a regulator.
Jim
Posted By: pkunk on 11/08/10 08:17pm
I had a Big Buddy hooked to a 1900 lb. tank (500 gal) for several years. No problems.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Print  |  Close
