RV.Net Open Roads Forum: General RVing Issues: RV Covers in Hot Climates
 > RV Covers in Hot Climates
dennysbabe
La Quinta, CA.
Posted: 11/03/10 10:00am Link  |  Print  |  Notify Moderator
I've seen a lot of posts for pros and cons for using rv covers in cold climates (heavy rain, snow, etc) but we live in the desert where heat is more of a factor than cold. Has anyone in a similar environment experienced problems in using an rv cover. Looking to buy one this weekend for our 5th wheel while they are on sale.
parkdep
Lapeer Michgan USA
Posted: 11/03/10 10:50am Link  |  Print  |  Notify Moderator
This guide may help Cover Guide
downtheroad
Pacific Northwest
Posted: 11/03/10 11:00am Link  |  Print  |  Notify Moderator
Just a thought.
Do you get a lot of wind (constant)?...often a desert climate condition?
One problem covers cause is chafing and damage that happens as the cover moves/shifts/flaps in the wind.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
dennysbabe
La Quinta, CA.
Posted: 11/03/10 11:10am Link  |  Print  |  Notify Moderator
Thanks for the link Parkdep. The Designer Tyvek by ADCO is the cover we're considering because it is recommended for hot climates but wondering if there is a drawback or negative we're not aware of.
We're also right on the border in length if anyone has any input on that. We're at 36'10" and the cover goes to 37'1". Wondering if better to be tight or loose. The next size goes up to 40' which would definitely be loose.
dennysbabe
La Quinta, CA.
Posted: 11/03/10 11:21am Link  |  Print  |  Notify Moderator
Thanks Downtheroad. We do get some wind but not constant. Scratching caused by dust under the cover is one of the concerns we've had as well as milldew from moisture (we don't get a lot of rain but some). Unfortunately we can't afford to install any type of shade structure because of the city's engineering requirements and we can already see effects from the sun constantly shining on it. It's either deal with risk of scratching from a cover or fading from the sun. Quite a dilemma!
Dick_B
Palos Heights, IL USA
Posted: 11/03/10 03:55pm Link  |  Print  |  Notify Moderator
I recommend TWO covers by Sunshield. The first one goes down with the silver side down and black side up. The top one goes down black side down and silver side up. The silver side, of course, reflects the sun and the air space between them acts like insulation.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
SkippysPad
Colorado.....I'm not qualified to be a
Posted: 11/03/10 06:49pm Link  |  Print  |  Notify Moderator
downtheroad wrote:
Just a thought.
Add to that the dust in a dry desert climate and you end up with sand paper on your finish. Anywhere the cover can move even a little and it's going to scratch or ding the finish. I'm not a big fan. I prefer a good wash and wax a couple times a year.
"> 2013 F-250 4x4 Crew, 6.7L Turbo Diesel, 5000lb Air Lift rear bags,
Equalizer 1200/12K Trunnion Bars
2015 KZ MXT 303 Toy Hauler">
2013 Yamaha FJR 1300, 2 dogs, Him & Her">
