RV.Net Open Roads Forum: Tech Issues: Suburban furnace troubleshooting
 > Suburban furnace troubleshooting
SPRING STREET
LOUISVILLE KY.
Posted: 11/07/10 09:12am Link  |  Print  |  Notify Moderator
Having problems with my furnace, fan runs but no heat. worked fine yesterday but went out sometime during the night. shut system down and reset the thermostat, fan comes on but sounds like the furnace doesn't ignite..any ideas and where do I look first?? thanks.. and yes I have plenty of propane!
2011 MOUNTAIN AIRE 4344, FMCA F334596, Cummins Power Play,Good Sams and KOA member..TOAD 2017 Ford Edge Titanium with a 6 cylinder Engine, License plate "TOWED" > RoadMaster Night Hawk Tow Bar and Base Plates. ">
downtheroad
Pacific Northwest
Posted: 11/07/10 09:39am Link  |  Print  |  Notify Moderator
Exactly what happened to ours...
Turned out to be a faulty "sail switch."
Replaced under warranty.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
answerswillvary
eastern washington
Posted: 11/07/10 10:07am Link  |  Print  |  Notify Moderator
Moved from RV Parks, National Parks, State Campgrounds & More
2009 Tiffin Allegro Bus 43QBP
JESTER7406
Northern California
Posted: 11/07/10 05:45pm Link  |  Print  |  Notify Moderator
sounds like the "sail" switch. It makes sure there is a spcified amount of air flowing through the unit before it allows gas to turn on and heat the air. I am assuming the unit turns on, blows cool air for about 30 sec, then turns off. Sometimes the rabbit cage fan is not moving enough air. If that is the case a small piece of foil tape can be doubled over to increase the surface area of the switch allowing the circuit to close and operate correctly. Any RV service center should be able to repair in about 1-2 hours depending how buried the furnace is.
Happy Trails,
Jesse
2006 Cheverolet 2500
29' Trail Sport
1 Worthless Choco-dog and WAAY worthless Puggle
JESTER7406
Northern California
Posted: 11/07/10 05:46pm Link  |  Print  |  Notify Moderator
forgot in the 1st post...
Perhaps the batteries went low overnight and caused decreased fan speed and thus not enough airflow to operate sail switch.
booty51
houston
Posted: 11/07/10 06:06pm Link  |  Print  |  Notify Moderator
I have the same problem my post is titled suburban furnace . One of the guys gave me a trouble shooting post with a manual read it it might help you outI am trying to test and see if Iam getting voltage to the board. Its like knocking over dominoes one leads to the other .
Booty
SPRING STREET
LOUISVILLE KY.
Posted: 11/07/10 09:27pm Link  |  Print  |  Notify Moderator
I was plugged into shore power so the fan continues to blow cold air..and I mean cold !!
SPRING STREET
LOUISVILLE KY.
Posted: 11/07/10 09:30pm Link  |  Print  |  Notify Moderator
Where is the sail switch located and is it an expensive piece??
mapguy
Puget Sound
Posted: 11/08/10 10:19am Link  |  Print  |  Notify Moderator
NT series Suburban requires furnace removal from coach to access the sail switch. Strongly suggest getting the Surburban service documents HERE and perform the troubleshooting routine from start to finish for the best results and minimize the amount of times you remove and install the furnance form the coach.
Something as minor as rust and scale in the burner chamber can prevent the sail switch from operating properly.....
beemerphile1
Ohio
Posted: 11/08/10 11:18am Link  |  Print  |  Notify Moderator
May seem elementary, but do you have LP? First thing I would check.
Even if you momentarily lost LP the furnace can "time out". To reset, turn the thermostat completely off to interrupt power and then back on.
2006 Weekend Warrior FK1900
