RV.Net Open Roads Forum: Can You Keep The Roof Vent Open While Driving Down The Road?
 > Can You Keep The Roof Vent Open While Driving Down The Road?
goreds2
OH H ..... EYE OH !
Posted: 11/13/10 09:46am Link  |  Print  |  Notify Moderator
Someone at work told me you can. Although, he does not have an RV either. [emoticon]
See Picture In My Profile
I have a 1989 Dodge XPLORER RV Class B - Purchased 10/15/10 IN CASH
Girlfriend purchased a Class C 2002 Dynamax Carri-go on 5/1/15 IN CASH
We've got the best of both worlds
RichTravels
New England
Posted: 11/13/10 09:49am Link  |  Print  |  Notify Moderator
Hi,
If you have a vent cover sure you can! If you just have a crank up vent I wouldn't drive with it open or you may find no vent at all when you arrive at your destination!
Happy Tails to all
Rich and Winslow the Newfie!
DraginRat
On The Road
Posted: 11/13/10 09:51am Link  |  Print  |  Notify Moderator
So long as you have them installed correctly. The opening muxt be to the rear so that the wind does not catch it, or have a vent cover installed.
We do it all the time, and I do believe they are designed for leaving open during travel
Ken Gasbarri
skipnchar
Topeka or somewhere else
They can be pretty fragile in windy conditions and even straight ahead apparent wind can take them off once they get a little old and more brittle. It also would be a VACUUM to bring in dirt and dust so not sure you'd WANT to do that and CERTAINLY wouldn't want to do it if driving on dirt or gravel roads.
dbbls
Arkansas
I have Maxairs and leave mine up all summer.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
tvman44
Southwest Louisiana
Posted: 11/13/10 09:58am Link  |  Print  |  Notify Moderator
Ours stays open 24/7/365 with the Maxair.
Papa Bob
Husky 16K hitch, Tekonsha P3,
btd35
Spokane, WA
Posted: 11/13/10 10:27am Link  |  Print  |  Notify Moderator
I have accidently left one open and had no damage, but I don't think I would do it again. If you ran into high side winds you could get some damage.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
SooperDaddy
Posted: 11/13/10 10:22am Link  |  Print  |  Notify Moderator
2 MaxxFans from MaxxAir and leave them open pretty much year round!
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
TURK2500
SE Michigan
Posted: 11/13/10 10:25am Link  |  Print  |  Notify Moderator
I wouldn't leave them open while driving, even with the MaxxAir covers. As stated, dirt and dust will be pulled into the TT. Been there, done it.
Depending on the location of your roof stink pipe, even some of the nasty smells could be pulled in. Been there, done it.
Turk2500
02 Chevy, 2500HD/4x4, 6.0L/4:10, GVWR 9,200lbs., GCWR 16,000lbs.
05 Jayco Eagle, 278FBS, GVWR 9,000lbs.
TV/TT loaded: 14,700lbs.
Loaded Tongue Weight: 1,300lbs.
Loaded TT weight: 8,500
Putnam XDR Class V, Reese HP Dual Cam.
brirene
midwest
Posted: 11/13/10 10:00am Link  |  Print  |  Notify Moderator
X2, with Maxair cover and tyvek in the winter.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
