RV.Net Open Roads Forum: Couple Of Small Cracks On Fiber Glass Roof - DIY Fix?
 > Couple Of Small Cracks On Fiber Glass Roof - DIY Fix?
goreds2
OH H ..... EYE OH !
Posted: 11/14/10 08:06pm Link  |  Print  |  Notify Moderator
While waxing today (I was not on the roof), I noticed these two small spider web (50 cent piece size) cracks. Is there any do it yourself fix for this or to maybe prevent it from getting worse? Thanks,
* This post was edited 11/14/10 09:05pm by goreds2 *
See Picture In My Profile
1990 Dodge XPLORER RV Van- Purchased 10/15/10
Chick Magnet !
* Sportsman GEN154 2000 Watt 80cc Portable Generator *
XM Satellite Radio since 12/25/2004
Sold my Class C 1976 Dodge TEC Motor Home 9/25/10
Gigger's F350 Fiver
North Bay
Posted: 11/14/10 08:13pm Link  |  Print  |  Notify Moderator
you can fiberglass it & then repaint that area, Gigger
PapPappy
Wilmington, NC
Posted: 11/15/10 07:31am Link  |  Print  |  Notify Moderator
It will depend on how much you want to invest and the level of your own repair skills.
It does look as if it is somewhat serious, and I'm wondering why you have these cracks here?? Is there something pushing through from the inside? You need to find that out first, so it doesn't get worse.
Get to a boat or auto shop, that deals with fiberglass, and get an estimate.
You can buy fiberglass repair kits from most auto-parts stores, and you should be able to make the repairs yourself. Biggest problem will be the color matching, but, if it's on the roof, and not really all that visible, that may not be as much of a factor.
Good luck with the repairs..
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
omjones
Stoney Point, Ontario, Canada
Posted: 11/15/10 09:04pm Link  |  Print  |  Notify Moderator
I used Eternabond tape. I had 4 holes where a storage pod had been removed. I filled it with a little bondo, then put the eternabond over the repairs. No problem for over 10 years. Just a warning though... this is great stuff but if you put it on, you ain't gettin' it off. This stuff sticks like 'God help ya'.
john 'I am Canadian'
goreds2
OH H ..... EYE OH !
Posted: 11/17/10 07:43pm Link  |  Print  |  Notify Moderator
Thanks for everyones inputs. I do not know why I did not think of eternabond in the first place.
I will probably go that route.
omjones
Posted: 11/19/10 03:34pm Link  |  Print  |  Notify Moderator
That's what we're here for!!!
landyacht318
Near a large body of water
Posted: 11/19/10 11:06pm Link  |  Print  |  Notify Moderator
The eternabond tape will certainly seal it. But it will also seal in some air, which will try to escape the next time your are at elevation, or on a super hot day.
There is a chance it will separate more of the Gel coat from the fiberglass. Once water gets in between the gel coat and the fiberglass, the delam will continue to spread. A lot of these roofs so have plywood or OSB inside. The gel coat is water tight, the laminating resin they used to make the structure is not. Water can/ will slowly seep inside. If it gets into the wood........
That type of gel coat delamination is either a sign of a good impact, or contamination after the gel coat was sprayed in the mold, before the fiberglass was layered on top of it.
See if the area underneath is soft. If it is, I would remove all the gel coat in the area, sand it down to bare fiberglass, re enforce it with more fiberglass matt saturated with polyester laminating resin. On top of the laminating resin, paint a layer of Sanding resin. Sand it smooth then just tape the area off and use some spray paint. This can be done for under 20 bucks. A roll of eternabond is what 55$
They do sell a spray on gel coat that cures like paint.
