RV.Net Open Roads Forum: Class A Motorhomes: furnace while driving?
 > furnace while driving?
jmanrambler
Brsitol RI
Posted: 12/05/10 08:18pm Link  |  Print  |  Notify Moderator
Is it ok to run the furnace while driving? Will the flame blow out? Should I just reply on my dash heat? Ive heard that if the flame blows out it will not automatically relight unless your turn the furnace off and back on again.
2006 Holiday Rambler Vacationer 37sbt Workhorse W24 Chasis
deedle82
High Desert, CA
Posted: 12/05/10 08:23pm Link  |  Print  |  Notify Moderator
That is a very good question, I did a few weeks ago and it was only because I forgot to turn it off. I am sure the Gradkids appreciated it. I will be waiting to see what other post.
Crazy Ray
Monroe,La
Posted: 12/05/10 08:26pm Link  |  Print  |  Notify Moderator
Run it or freeze simple
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Mr. Jeff
Edmond, OK
Posted: 12/05/10 08:32pm Link  |  Print  |  Notify Moderator
You can run with it on ~ they're built with proper air dams and venting to allow operation while in motion. However, make sure it is off while refueling at the pumps!
Jeff, Leslie, Boston (Golden Retriever) & empty house
(some kids married & gone, others in college)
2000 Tiffin Allegro Bus (37,000 miles)
22' MacGregor, Hobie 16
Eycom
32043
I've traveled for short stints up into western NY and PA during the winter. Had to keep the furnace running to keep the plumbing operational. Aside from using a lot of propane, I had no issues.
RVn Full-time
thunderstruckhd
Ft.lauderdale and Key West,Florida
Posted: 12/05/10 08:34pm Link  |  Print  |  Notify Moderator
Run it, it will not blow out. It's designed to be run while driving as is almost everything else in yout RV...
Prevost H3-45 Featherlite Vantare
500HP Series 60 Detroit Diesel
Assorted trailers,toys and toads
And Zoie the Doberman.(01/26/01 - 07/23/11) R.I.P.
jmanrambler
Brsitol RI
Posted: 12/05/10 08:35pm Link  |  Print  |  Notify Moderator
Can it simply run off the engine alternator or will it be too much of a strain to keep the batteries charged, should i run the genny for the furnace?
AustinFlash
Austin, Minnesota
Posted: 12/05/10 08:45pm Link  |  Print  |  Notify Moderator
In every motor home I have owned I run the furns. No problem, living in MN it gets cold and we have traveled in really cold weather 22 below zero (0). No furn. you would freeze. Last weekend traveled to SD and was 0 degrees the morning we left to come home ran both furns, No problem. Run them the same as if you are stopped. And they are 12 volt so your not putting a load on the gen. on the engine. Never had a problem with it keeping up and keeping the batteries charged. No need to run you gennie.
AustinFlash
Austin, Minnesota
Posted: 12/05/10 08:47pm Link  |  Print  |  Notify Moderator
Still says I'm a new member even tho been with this sit sense 05 LOL.
goreds2
OH H ..... EYE OH !
Posted: 12/05/10 08:54pm Link  |  Print  |  Notify Moderator
It must depend on how many posts you have. (22) [emoticon]
See Picture In My Profile
I have a 1989 Dodge XPLORER RV Class B - Purchased 10/15/10 IN CASH
Girlfriend purchased a Class C 2002 Dynamax Carri-go on 5/1/15 IN CASH
We've got the best of both worlds
