RV.Net Open Roads Forum: Class A Motorhomes: Pulling a boat with your Motorhome
 > Pulling a boat with your Motorhome
RHappykamper
Posted: 12/24/10 07:51am Link  |  Print  |  Notify Moderator
The wife and I love to fish, we fish couples bass tournaments, some of our tournaments require staying over a night or two, I really don't want to take an extra vehicle to load and unload the boat but I can't come up with a very good solution, maybe have another couple dump us in the water and then load us back up, that would be asking a lot, anyone have any other ideas ?
JoeH
Apollo Beach,FL
Posted: 12/24/10 08:05am Link  |  Print  |  Notify Moderator
I sometimes tow a 22 ft boat behind the MH and haven't had any issues unloading/loading. The long rear overhang keeps the rear wheels on good footing.
Ivylog
Blairsville, Ga. USA
Posted: 12/24/10 08:31am Link  |  Print  |  Notify Moderator
The 39-L you are looking at has enough rear overhang to keep the tires out of the water and makes it easy to back up even a short trailer. The transition onto a steep ramp may be your biggest problem from high centering and on a steep ramp you might want to use wheel chocks as a "just in case". Helps to have something sticking out from each side of the back of the boat trailer so you can see what's happening sooner in your mirrors.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
JFG
TN
Posted: 12/24/10 08:33am Link  |  Print  |  Notify Moderator
I see many traveling south down I-75 to FL. take a trial run to one of your local lakes.
Fred
mowermech
Billings, MT
Posted: 12/24/10 08:45am Link  |  Print  |  Notify Moderator
I tow a 17 foot Bell Boy fiberglass boat behind my 29 foot Tioga. I have no trouble launching or recovering the boat with the motorhome.
I do recommend a tandem axle boat trailer, though. I find the tandem axle much easier to back than a single axle. It just seems to track straighter. Perhaps it is just an illusion, but it works for me...
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
YC 1
Yuba City Calif.
Posted: 12/24/10 08:53am Link  |  Print  |  Notify Moderator
If you are at club tournaments finding a friend to dump you in and pull you out is usually quite easy and a refreshement is not much of a cost. I launched with my C mh's and then my 30 ft A. I don't think I will launch with the one I have now though.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
427435
Rochester, Mn
Posted: 12/24/10 09:25am Link  |  Print  |  Notify Moderator
I've never found towing or launching my boat to be an issue. A chock for your DW to put behind the rear wheels before you get out of the cab is a good idea. Either that or put her in the boat and do "bonsai" launch.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 74,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
NoGoSlo
Walnut Creek, CA, USA
Posted: 12/24/10 12:11pm Link  |  Print  |  Notify Moderator
I have a 38 foot DP. When I can't launch because of a tight turnaround for a launch ramp, I can always find someone in the area that will launch my boat, all boaters are "friends."
B & B
Yellow Labs: Rusty & ZBar
Monaco Dynasty DP
