RV.Net Open Roads Forum: Fifth-Wheels: TV IN BASEMENT OF FIFTH WHEEL
 > TV IN BASEMENT OF FIFTH WHEEL
M GO BLUE
Southgate, MI
Posted: 12/25/10 04:36pm Link  |  Print  |  Notify Moderator
We want to put a 22" - 26" LCD/LED TV in the bottom compartment of our fifth wheel so we can view it when we are sitting outside. We don't have one there now nit have all the hookups needed for the TV,
Our question is for those of you who have installed one down there have you mounted it to either the basement ceiling so it swings down or the side wall where it swings out OR do you just put it out there when you arrive at your site and then back inside the fifth wheel when you leave?
If you have it mounted inside the compartment how do you protect it when traveling?
Thanks!
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
hawkhill
Posted: 12/25/10 04:45pm Link  |  Print  |  Notify Moderator
We have a 26" which we carry in its box on the side of our basement slider. When we get to a campsite we set it up at the end of the slider. We have all the connections built into the side of the basement, but were not comfortable coming up with a mounting solution. We looked at side mounts that would swing it out and flip mounts that would flip it down from the ceiling of the compartment, but could not come up with one that gave us no clearance problems and protected the set. As it is we are happy with our solution, if we are staying shortterm and need more storage space, we can just leave the TV at home.
2015 RAM 3500 dually Deep Cherry Red Crystal 6.7 Cummins Aisin 6-Speed
2008 Carriage Cameo F35SB
Jeff "Loving DH"
Smokey & Purrshing, Our Ragdolls
Gordie, Springer Spaniel
True Blue, Aussie
Jim Cindy
Northcentral, PA
Posted: 12/25/10 08:18pm Link  |  Print  |  Notify Moderator
We carry a 32" lcd tv in the basement. We have no special mounts, It travels with the screen towards the front and coved with a padded vinyl cover the DW sewed up. When we park I just turn it around and set it on top of the DVD player and the Dish box. Currently on an around the country trip, Central PA to Washington, down Oregon coast, across Nevada, Arizona, New Mexico and now on South Padre Island, TX
Waiting for the bowel games.
Note on Fifths with heated basements, the open compartment allows easy access for flying pests. I got a large piece of mosquito netting, stick it to velcro tape mounted on the wall around the inside of the compartment opening and drape the netting over the TV down to the floor. Works for us.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison ">
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Jim Cindy
Northcentral, PA
Posted: 12/25/10 08:21pm Link  |  Print  |  Notify Moderator
OOPS, Should be BOWL games, unless of course your New Years food tradition is sauerkraut and pork.
waroland
Mt. Juliet, TN
Posted: 12/25/10 08:47pm Link  |  Print  |  Notify Moderator
Mine is mounted to the front wall with a locking swing mount.
Basement TV
2002 Fleetwood Revolution
2006 Honda CR-V toad
jbc28
Gadsden, AL
Posted: 12/25/10 08:54pm Link  |  Print  |  Notify Moderator
I thought about mounting one in the basement, but decided against it. I just put the one from the bedroom in the basement or sometimes sit it on the table under the awning. I keep too much junk in the basement to carry a fragile tv too.
06 F350 DRW cab & chassis, CM bed, 4x4, crew cab, Lariat
05 KZ Sportster 37KX2L
R-D
Arroyo Grande, CA.
Posted: 12/25/10 09:34pm Link  |  Print  |  Notify Moderator
We installed a 32 inch flatscreen TV on a swing arm bought at Costco. We installed on side wall, it swings out for easy viewing. We sometimes place a thick piece of foam against the screen depending on how close we have items to the TV. First we had a 22inch TV but ended up being too small a screen unless we were sitting on top of it. Now we can push back and sometimes sit around a campfire and still see the screen. Happy Camping !
jetboat
Arizona
Posted: 12/26/10 07:18am Link  |  Print  |  Notify Moderator
We have one,and its just sitting there.The only problem we have is during certain times of the year,bugs of many types like the light of the tv,some time is just a pain in the butt to watch anything.
SoCalDesertRider
Arizona desert
Posted: 12/26/10 09:20am Link  |  Print  |  Notify Moderator
I have seen them mounted upside down to the inside of the flip-up basement door, so that when the door is open, the TV is right side up with screen facing out for viewing.
I have also seen them mounted to a swing out arm which is mounted to one of the dividing walls inside the cabinet.
Whatever you do, make sure your other cargo is very secure so it doesn't slide into the TV while underway and break it!
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
laknox
Arizona
Posted: 12/26/10 04:40pm Link  |  Print  |  Notify Moderator
Some manufacturers (Montana?) have a swing-out bracket in the basement, will all the connections in place, and you simply take the bedroom screen out and put in place in the basement. Not huge, but nice.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 60 Year Member
