RV.Net Open Roads Forum: My DIY projects
HSIKES
Wilmington,NC
Posted: 01/05/11 05:20pm Link  |  Print  |  Notify Moderator
My bride along with many others were not pleased with the Convection/microwave fan system. All it did was to send the hot air back into the motorhome.
After reading post on how to change the set up, I decided to try and tackle it.
First I removed the microwave and figured out where the exhaust fans would blow the air. Not having a duct system I made one in my shop. The hole was cut 6" and I found a vent at Lowe's for about $7.00
Looking from the inside showing the bracket holding the microwave.
The plastic vent was white so I painted it black so it would not be noticed.
Another project was a very small compartment on the drivers side in the front. It was only 13" deep and any thing you put in would greet you when you opened the door. I decided I would use some scrap plywood to make tool drawers for loose items. Not furniture quality, but it's functional.
I made the bottom drawer larger so cans would be able to stand up and not roll around.
NEXT PROJECT:
I also modified the water compartment in my Fleetwood. You had to hook up a hose for house water, another for the black tank flush, I also use a sewer solution so there is another hose, and of course my Grand daughter wanted a hose to fill her wading pool. All you did was play musical hoses with "y's" ever where [emoticon].
Went by the wholesale plumbing store and purchased a 4 gang manifold that they use in new home construction. Soldered the hose bib to one end to supply the incoming water from the CG water supply. I connected one valve to the house water with 1/2" Pex and a back flow valve. Another valve was plumbed to the black tank rinse with another back flow. Third valve has a hose bib so the little ones can fill their pool with a hose that they pull under the motor home. And last but not least is the sewer solution water supply with another back flow valve.
I don't believe that you can have too many back flows [emoticon]
Now when I get to the CG it's a simple process. I just hook up one water hose, run the sewer solution drain hose to the sewer, plug in the electric and hook up the TV and I'm all set.
Open and close valves as needed and no more messy hoses, rubber gloves and slinky stinky.
Many more projects on the list, but I get inspired from your post.
Horace
* This post was last edited 01/06/11 05:52pm by HSIKES *   View edit history
Horace & Bobbi
DRAKE - Yellow Lab (rescue dog)
2005 Fleetwood Providence 39 L; 4 slides; 350 Cat
2000 Saturn LW TOAD
2009 Buick Enclave CLX 2
Preach the gospel at all times. And if necessary.....use words.
ronfisherman
SE Michigan
Posted: 01/05/11 05:59pm Link  |  Print  |  Notify Moderator
Projects look great. But pictures are so small cannot make out what some of them are showing.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
HSIKES
Wilmington,NC
Posted: 01/05/11 07:11pm Link  |  Print  |  Notify Moderator
* This post was last edited 01/06/11 05:50pm by HSIKES *   View edit history
Dolan Brown
North Carolina
Posted: 01/05/11 06:10pm Link  |  Print  |  Notify Moderator
ditto
2006 Tiffin Phaeton 40 TSH
2003 PT Cruiser LE (Toad)
RoadMaster Tow Bar with Blue Ox Baseplates and Air Force One
Jozzieo
Home based in K.C., Mo. (location may vary)
Posted: 01/05/11 06:11pm Link  |  Print  |  Notify Moderator
Great Mods, makin' life better on the road, that's what it's about.
Jim and Sue Osbern,
08 Ford Super Duty 3/4 PSD 4x4 lariat Crew Cab. '07 3400RL Montana, Maytag's with 220 dryer, Satdome, Rear A/C unit, Digital amp Gage, Vena tank monitor, Rear camera, 3,000W. Inv, Roto chocks, air bags My Mod's
Jozzieo
Posted: 01/05/11 07:26pm Link  |  Print  |  Notify Moderator
HSIKES wrote:
I enlarged the pictures to 640 and now they are blurry.
Sometimes the Mods are easier than the pictures [emoticon]
I wish I could help.
HSIKES
Wilmington,NC
Posted: 01/05/11 07:36pm Link  |  Print  |  Notify Moderator
deleted [emoticon]
* This post was edited 01/06/11 05:50pm by HSIKES *
PSU_RVr
PA
Posted: 01/05/11 07:39pm Link  |  Print  |  Notify Moderator
Not sure about how you posted them on photobucket. But either the originals are that small, or there is a setting on PB that limit how big the URL posts. Not familiar with PB, so I can't help more than that.
Newmar Canyon Star 3920 Toy Hauler
Where it's been, the crew -Bandit, Morgan, Sherman. It:
Jozzieo
Posted: 01/05/11 07:41pm Link  |  Print  |  Notify Moderator
If the photo's are in an album on PB, just get the link and post it.
fla-gypsy
North Florida
Posted: 01/05/11 07:58pm Link  |  Print  |  Notify Moderator
Nicely done
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
