RV.Net Open Roads Forum: Fifth-Wheels: How to make a 5th wheel four seasons?
 > How to make a 5th wheel four seasons?
ColoradoMike
Colorado
Posted: 01/21/11 12:12pm Link  |  Print  |  Notify Moderator
Hello, We have a KZ New Vision 37' fifth wheel that did not come from the factory with the four season package.
While we seldom camp in winter we live in Colorado and some of our early and late season trips have found us in pretty cold temps. In one case our pipes did freeze and the heater couldn't keep up. We did get the insulated windows when we ordered it.
My questions is what would I need to do to make this a 'four season' rig? Presume we'd need to insulate and close in the underbelly plus maybe add heaters to the tanks. Is there something else we should consider? Also, where do I get these parts and is there some instructions on how to do it?
Called my dealer but they said it would cost several thousand dollars to do this so I'd like to at least look at doing it myself. Any help or direction would be appreciated!
ColoradoMike
Mike and Brenda from Colorado
2008 KZ New Vision Sportster 37KGx2 'Side Door' Toy Hauler
2005 Chevy 3500 2WD Dually Diesel
2005 Harley Davidson Electra Glide Ultra Classic
wandering1
Posted: 01/21/11 01:50pm Link  |  Print  |  Notify Moderator
So what did the dealer say that they would do to make it four seasons for several thousand dollars... thats your answer.
HR
Dandy Dan
Findlay, Ohio
Posted: 01/21/11 02:17pm Link  |  Print  |  Notify Moderator
Mike, I have already an enclosed heated underbelly but no actual tank heaters. I had also checked into having the windows taken out and have thermo-pane put in but at the time it was cost prohibitive. I think it would have been around $2500 just for the windows and who knows how much for the labor. I think your best bet would be to check on having the underbelly insulated more, heaters on the tanks and/or valves and have heat being ducted through the underbelly. It may be a bigger job than you might want to tackle but Good Luck with whatever you decide.......Sorry, I didn't see you had dual pane windows.....
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2014 Chevy 3500HD Crew Cab
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
Rescuebub
Relaxing in MD
Posted: 01/21/11 03:56pm Link  |  Print  |  Notify Moderator
Please keep us posted on what you come up with. I am considering doing the same, or atleast the tank heaters and heat tracing. I know someone on the TT forum posted about a type of spray foam insulation to coat the underbelly instead of complete enclosement, but, if I remember correctly, it was kinda expensive also. Good luck and happy camping!
11 Jay Flight G2 32BHDS
2008 Silerado 2500HD 4X4 Z71 6.0L, 6sp.
Reese Dual Cam, Prodigy
Me,DW,DD,2 Pups
SteveRankin
Sequim, WA
Posted: 01/21/11 03:59pm Link  |  Print  |  Notify Moderator
A true 4-season RV is designed to be exactly that from the gitgo. Of course, there will still be optional items such as double-pane windows and tank & plumbing heaters for those that are even more serious about it.
What I read in your OP was that the heater could not keep up with the cold and one result was that some plumbing lines froze. I'm not surprised. Your 37' KZ with 3 slides has a smaller furnace than our 24' 1-slide Arctic Fox. We have a 35KBTU furnace to heat 230 sq feet (152 BTU/sq ft) while you only have 30KBTU for 400 sq ft (75 BTU/sq ft). That's a huge deficit to overcome, especially without even talking about the differences in design.
While, I doubt that you can completely solve your problem there are things you can to that might help:
1. Replace the furnace with a 42KBTU model.
2. Install electric tank heaters and all holding tanks and FW tank.
3. Install electric water line heaters and/or insulation of plumbing in the basement.
4. Add insulation to the basement.
5. Bring the slides in at night.
6. Shut the furnace vents in the garage area and run a 120VAC space heater in the garage area instead. That will increase the furnace flow to the basement.
Steve & C. J.
Gracie Rough Collie
Bo'sun Bichon Frise
Marli Lab
2011 Fox Mountain 245RKS
1998 Bigfoot 25C9.6B
2010 Dodge Ram Laramie 3500 4X4, Cummins 6.7, Crewcab SRW LB
TrailerSaver BD3 & MOR/Ryde
Our Arctic by RV trip
Our Beaver motorhome Technical page
NMace
Central Arkansas
I, too, hope we get some serious answers.
To complicate the matter I have an outside shower and kitchen.
I think I just need a cut-off for them, and perhaps the tank heaters.
Just don't know.
I really don't need four season, just protection when it gets below freezing overnight,
Neil
2002 Silverado 6L 1500 HD 4x4 Crew Cab
2011 Puma 295 KBHSS
ColoradoMike
Colorado
Posted: 01/21/11 04:31pm Link  |  Print  |  Notify Moderator
Found some tank heaters online and called another dealer to see if I can get more info. Will let you know what I find out!
Thanks for the responses.
ColoradoMike
Colorado
Posted: 01/21/11 04:33pm Link  |  Print  |  Notify Moderator
Steve and CJ,
Just saw your response, great info and it makes sense why the heater works so hard and it is still cold.
Rolling Condo
South Carolina
Posted: 01/21/11 08:27pm Link  |  Print  |  Notify Moderator
No reason why you can't go out and camp in the winter with some preparation. Here's my collection of links on preparing to camp in winter.
Drafty Slidesn winter RV'ing.
Winter Camping
Winter Camping in Denver
Lots of information that I've been gathering on the subject.
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
jetboat
Arizona
Posted: 01/21/11 09:30pm Link  |  Print  |  Notify Moderator
Have a 2009 sandpiper 345ret. with alot of windows,and the underbelly is heated.However,it still did not cool off as we thought it should ,and the heater ran more than we also thought.Solution,bought some 4x8 1" thick ridged insulation form lowes.lined the storage compartments,and fitted some windows with the insulation.This past summer,with 3 super slides,the air units worked less,and lasts years winter camping,only ran the elect. fire place,no heater.
The insulation really helped and is around $13.00 a sheet.
