RV.Net Open Roads Forum: Full-time RVing: temporary underpinning
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > temporary underpinning
psych prof
houston, texas
Posted: 02/01/11 05:13pm Link  |  Print  |  Notify Moderator
Any ideas on a way to temporarily underpin a travel trailer. We don't want to spend hours getting the RV ready to roll again on short notice. Thanks.
2oldman
Orland
Posted: 02/01/11 05:23pm Link  |  Print  |  Notify Moderator
Can you explain what 'underpin' means?
Rolling Condo
South Carolina
Posted: 02/01/11 05:47pm Link  |  Print  |  Notify Moderator
RV Skirting
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
psych prof
houston, texas
Sure. Underpinning is a method that creates a perimeter barrier that acts as insulation. Sorry for the lack of clarity.
d-bsearcy
Columbus ,NC USA
Posted: 02/01/11 05:51pm Link  |  Print  |  Notify Moderator
I saw a travel traier underpinned with bales of hay. You say it was temp but most likely will stay until grass gows out of the bales.
2011F350 6.7 liter PowerStroke Lariat crewcab LB dually FX4, White over Gold">hino liner,Towcommand , 2011 Cedar Creek 40RL5 2007 Harley ultra classic ,2006 Harley soft tail Deluxe,2011 Yamaha FZ Cruiser SHO Waverunner 2012 Yamaha AR240
Carolina Cruiser
East TN
Posted: 02/01/11 06:02pm Link  |  Print  |  Notify Moderator
Hay bales or straw work very well but the best thing to do is put them in heavy duty Lawn and leaf bags to keep them dry. When you are ready to roll again you can donate them as they will still be in good shape.
Albert & Tamara, the dogs Casey & Cody, Living the simple life.
God never said Saved by Grace;kept by performance.
skipnchar
Topeka or somewhere else
Posted: 02/01/11 06:20pm Link  |  Print  |  Notify Moderator
If you're talking about enclosing the belly to protect tanks and plumbing, there's probably not much you can do on a temporary basis. It takes me over an hour to remove just one panel of my belly pan. while you MIGHT stick something under there to close it off, it's probably not going to do much good without being pretty tightly sealed. Also, even with a closed belly you still need a means of HEATING the enclosed belly. Either electric pads on tanks and plumbing or a furnace vent open into the belly if tank heaters aren't available. Several days ago would have been the time to start taking these steps. As others have suggested you may provide some small amount of help by simply skirting your trailer using whatever you can. wont add heat but it can keep drafts down a little bit. without heat things will still freeze in the open belly just as fast but it may stay warmer inside the trailer. Good luck / Skip
WTTCS
freedom , U.S.A.
Posted: 02/01/11 09:09pm Link  |  Print  |  Notify Moderator
Carolina Cruiser has it right, we did this for many years in Zero weather. But use the heavy duty trash bags .
1997 chev crew cab 454, 5 sp. 4.10
TXiceman
Full Time RVer
Posted: 02/05/11 04:14pm Link  |  Print  |  Notify Moderator
Any kind of perimeter barrier that is hay or leaves will attract little four legged critters looking for a warm place to bunk. You can buy a soft skirt that is manufactured to fit your trailer. A simple barrier is some of the foil backed, 1/2" thick foam board from Home Depot. Join the sections with foil tape, cut with a kitchen knife and secure with a few 1 x 2 wood stakes.
Ken
Amateur Radio Operator.
WTTCS
freedom , U.S.A.
Posted: 02/05/11 05:10pm Link  |  Print  |  Notify Moderator
Soft skin doesnt insulatae , hay does, and if in the right trash bags, mice or others cant get it, especially if you put animal repelent in them.
We used em for many many years, and never had any trouble .
