RV.Net Open Roads Forum: Class C Motorhomes: Two Fluids for E450
 > Two Fluids for E450
j-d
Sunny Florida USA
Posted: 02/14/11 10:36am Link  |  Print  |  Notify Moderator
Vehicle in Signature...
I've decided I want to change the rear axle lube and check the lube level (add if needed) in the transmission-mounte driveshaft parking brake.
"Axle" code on door sticker is "83" and owner's manual says "Dana 9.75-in M60-1U, 10.5-in M70-2U, M70-1HD" Motorcraft SAE 80W-90 Premium Rear Axle Lubricant XY80W-90-QL Ford Spec WSP-M2C197-A. This sounds like a non-synthetic. Then footnote "8-oz Additive Friction Modifier C8AZ-19B546-A Ford Spec EST-M2C118-A". This is noted for all the Dana axles whether standard or limited slip/traction-lock.
I'd like to go to a synthetic lube that meets both the lube and the additive specification. Has somebody identified a lube that meets this?
I don't know if it's a 9.75 or 10.5 axle, but it seems capacity's a little over 3-qt. If I need to crawl under to look for a tag or stamping, I can do that, just let me know.
Parking Brake - Apparently it's used only on E450, has its own fluid supply of a few ounces, and the fluid might be a Ford item. The owner's manual does not talk about the brake, its lubricant, or how to check/add it.
Does anybody have info on it?
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
CloudDriver
New Jersey Shore
Posted: 02/14/11 11:43am Link  |  Print  |  Notify Moderator
The Ford maintenance schedule for our 2003 E450 says to change the rear axle lube at 100,000 miles. I'm going to wait until I get there to do that.
The parking brake fluid is transmission fluid - pretty sure it is Mercon.
2003 Winnebago Minnie 24F - Ford E-450">
Dave n Holly
Lansing IL
Posted: 02/14/11 12:25pm Link  |  Print  |  Notify Moderator
x 2
2009 Coachman Freedom Express 31
2009 Ford E450 Super Duty Triton V-10
Quadra Bigfoot Auto Levelers
j-d
Sunny Florida USA
Posted: 02/14/11 03:54pm Link  |  Print  |  Notify Moderator
The specified interval's fine.
The lube in This Axle looks sick.
So I'd like to know what kind to put in it. Soon.
Pokey2
Bel Marin Keys, CA
Posted: 02/14/11 04:24pm Link  |  Print  |  Notify Moderator
Hi j-d
You have been of so much help to so many others on these forums. Wish I could help you on your question, but I can’t.
I think I speak for a lot of us when I say “Thank you” for your many past contributions. Now, let’s let the experts continue to have at it for your question.
Good luck!
j-d
Sunny Florida USA
Posted: 02/14/11 04:47pm Link  |  Print  |  Notify Moderator
Thanks, Chris! I've gotten SO much help on this and other forums that it's great to pay some of it ahead.
Somebody'll be along that's got enough miles to have done that fluid change.
I may be able to dig it out by reading bottles at the auto supply. Just sitting right now in a campground thinking of the next project(s) I have to get moving on. Trying to get a head start.
CloudDriver
New Jersey Shore
Posted: 02/15/11 08:02am Link  |  Print  |  Notify Moderator
Check with the parts/service department at a Ford dealer to see what they use. If in doubt, call two dealers and see if you get the same answer.
fireflock
NC
Posted: 02/15/11 09:00am Link  |  Print  |  Notify Moderator
My 2003 E-450 manual had a phone number in it for Ford Motorhome Chassis tech info, or something like that. I called them once to ask for a recommendation about a substitute trans fluid (original spec discontinued). Mine is in storage, but maybe someone can dig up the number?
FWIW - the guy on the tech line said to call the local dealer. The tech line actually wasn't much help in my case.
j-d
Sunny Florida USA
Posted: 02/15/11 09:24am Link  |  Print  |  Notify Moderator
Thanks, guys! I'll continue to monitor this thread and try a little local shopping and see what I can generate. Hopefully I'll find something that says "meets Ford Specs X, Y and Z."
This is the only vehicle we own that's involved in synthetic lubes. Using full syn engine oil and amsol ATF. Both were installed by prev owners. They said the axle'd also been changed but I don't think their recollection was right. Well, one of our "vehicles" a boat with MerCruiser stern drive, uses MerC's synthetic outdrive lube... But since most seem to agree that syn holds up better than dino when life gets tough, I'd like to do the best I can for this hardworking rear axle.
Thanks again.
j-d
Sunny Florida USA
Posted: 02/23/11 11:07am Link  |  Print  |  Notify Moderator
What I've found is the two Valvoline lube products, pure dino oil and their blend product, both meet the Ford spec for the lubricant. Even though they are listed as "also for limited slip" they don't meet the friction modifer supplement spec. There's a 7-oz tube of K&W Posi-Trac Trans-X that does. Other lubricant brands, such as Mobil-1 pure synthetic, Lucas, and Coastal dino, do not address any Ford specs.
That tells me I could go Valvoline Dino plus Trans-X and next service interval 100,000 miles. I don't know if going to the Blend would help any.
Does this info trigger any thoughts?
