RV.Net Open Roads Forum: Tech Issues: 87 Coachman Leprechaun Heater/fridge problem HELP!
 > 87 Coachman Leprechaun Heater/fridge problem HELP!
peak1nc
North Carolina
Posted: 02/14/11 03:32pm Link  |  Print  |  Notify Moderator
We just took our "NEW" to us Leprechaun out for the first time. Before leaving, we had tested the heater, it came right on and got the camper nice and toasty. I tested the fridge by leaving it running on gas overnight. We put the setting on "coldest" We were surprised to find the fridge temp at 20 degree's the next day. Well off we went. We arrived at the campsite, turned on the heater as it was 45 degree's outside. It came right on blowing out hot air. I turned on the fridge using the gas setting. No "Check" light, so I presumed it was working. We went outside for the next few hours, and when we came in, the camper was cold. I checked the heater, it was blowing out cold air. Also the fridge was not cooling. I turned it off, and turned it back on, immediately the check light came on, and continued to come on every time I tried to start it. Also, shore power would not run it. At first I thought I was out of gas, but the stove and oven worked fine the entire trip. We had ceramic heaters and put blocks of ice in the fridge so all was well, but I am really confused about the heater/fridge issue. Can any kind soul offer any help or hints on what could be wrong? TIA!
Kirk
Livingston, Texas.
Posted: 02/15/11 09:46pm Link  |  Print  |  Notify Moderator
It may be that your propane pressure regulator is bad and the supply pressure is low. That could cause the two not to operate, but it would not effect the refrigerator's ability to run on shore power. I would have the gas pressure checked.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
computerbug
Sarasota
Posted: 02/15/11 10:25pm Link  |  Print  |  Notify Moderator
Ck the ground fault in the bathroom, also the breaker might have tripped. This happened to us last wkend. Ours is a Santana Good Luck
Harvard
51.6N 114.7W
Posted: 02/15/11 10:54pm Link  |  Print  |  Notify Moderator
If it is not the LPG regulator then it could be an oil trap in the LPG distribution cutting off flow to some appliances. This type of problem is typically intermittent with outside air temperature as the oil viscosity increases as it gets cold.
peak1nc
North Carolina
Posted: 02/18/11 06:28pm Link  |  Print  |  Notify Moderator
Thanks for the replies folks! These replies definitely give me some avenues to pursue. I have tomorrow off, so will check them all. Thanks again to all of you.
fisher60
Plant City, Florida
Posted: 02/18/11 06:51pm Link  |  Print  |  Notify Moderator
Battery dead? No 12 volts to the appliance, no workie!
'01 Dutchman Express 28A, Borg Chrome Dually Valve Stems, Pacific Dualies Wheel Simulators, '06 Tuscon, 2014 FLHTCUTG
Good Sam Life Member
peak1nc
North Carolina
Posted: 02/20/11 12:56pm Link  |  Print  |  Notify Moderator
Ok. Got 14.1 volts reading on the battery. I got the RV very level. Turned on the furnace, got heat. Turned on the stove, got a flame. Still nothing to the fridge. Took the igniter cover off, and had the wife switch from off to gas. The "Check" light came on immediately. No ignition, no spark nothing. Checked the breaker panel on the bed. Nothing tripped, and all fuses are fine.
dog_walker
home
Posted: 02/22/11 08:07am Link  |  Print  |  Notify Moderator
I have an 87 Coachmen Crusader, I have had my fair amount of issues with my gas appliances as well! I'm not sure as to why, but my fridge on gas will only ignite while connected to shore power. Once ignited, I can disconnect.
dog_walker
home
Posted: 02/22/11 08:15am Link  |  Print  |  Notify Moderator
After re-reading you're last post you said you measured 14.1 volts on you're batter, so that must have been while plugged into shore power.
