RV.Net Open Roads Forum: Tow Vehicles: Too low of a gear ratio?
Search only in Tow Vehicles
 > Too low of a gear ratio?
Page of 8
mkirsch
Rochester, NY
Posted: 02/17/11 08:02am Link  |  Print  |  Notify Moderator
Humor me for a few minutes here...
It baffles me why someone would think that a mid-2000's Dodge 5.7 Hemi pickup with 3.55 gears works well for pulling an 8000lb trailer in the Rocky Mountains, while someone with the same engine and 3.92 gears thinks it "struggles" on the flat with a similar trailer.
Simply put, the Hemi does NOT have enough power to pull an 8000lb trailer in overdrive with EITHER gear ratio, except downhill with a tailwind.
In 3rd gear, the 3.55 truck is running at about 2800 RPMs. Tolerable.
On the other hand, the 3.92 truck is running at about 3200 RPMs. That's getting a little loud.
The people with the 3.55s leave the truck in 3rd and have plenty of power for most conditions. On the other hand the 3.92 drivers are trying to get the truck back into overdrive all the time, so it's grunting, and struggling, and shifting frequently.
* This post was edited 02/17/11 10:16am by mkirsch *
mich800
Pontiac, MI
Posted: 02/17/11 08:15am Link  |  Print  |  Notify Moderator
I do not think the Hemi was offered until the early 2000's. But I agree with the rest. Gearing is a compromise. The only time I ever got into OD with my Ford 5.4 was maybe going downhill. But I did not have a problem wringing it out on the hills if that is what it takes.
big dave
Soldotna, Alaska, USA
Posted: 02/17/11 08:34am Link  |  Print  |  Notify Moderator
Chrysler built a few hemi engines during World War 2 but none ever went into production. One developed over 3,000 h.p in a V16 configuration. The first hemi mass produced for an automobile was Introduced in the fall of 1950 as a 1951 model, the Fire Power 331 V-8 was offered as on option in the Saratoga (except for the coupe models), while it was standard in the New Yorker and Imperial.
Read more: http://wiki.answers.com/Q/When_was_the_hemi_introduced#ixzz1EEMk4JCb
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
skipnchar
Topeka or somewhere else
Posted: 02/17/11 08:37am Link  |  Print  |  Notify Moderator
Sounds like you believe (and I agree) that you have too HIGH a gear ratio. The REASON some use economy gearing like 3.55 or even higher yet like 331 instead of towing gears like 4.10 is because towing isn't a big priority with about 80% of the trucks on the road. They're built for and used for towing groceries home from the store once a week. You will notice that the tow RATING for a truck with economy gearing is for less weight than one with tow gears. While it IS possible to tow with higher gears it is FAR from pleasant to be traveling up a minor grade like 06% as found on Interstate highways at 30 MPH while others are passing you at 70. Not pleasant and downright dangerous. Good luck / skip
enginemasterguru
near Bear Lake
That's just silly.
Once I used a 165-HP ( at 4000 rpm ) 4.3, with 3.73:1 axle, to tow a 7500 pound load up a 6% grade, and I made it without struggling. I was doing 30 mph at 4400 rpm in first gear, but it didn't hurt anything. I didn't even turn the radio up.
A 5.9 or a hemi will tow 8000 pounds with a 3.55:1 axle. No worries.
If you don't like RPM, then switch to diesel.
mich800
Pontiac, MI
Posted: 02/17/11 08:49am Link  |  Print  |  Notify Moderator
I meant after its hiatus. I am aware there was a hemi prior to 20xx.
ib516
Way up north eh
Posted: 02/17/11 09:23am Link  |  Print  |  Notify Moderator
Well, not a Hemi, but I can tell you from experience that a 360 cu in gasser (245hp) did not have enough power (FOR MY TASTES) towing 8500 - 9000# in the mountains, even with 4.10 gears. ~30 mph up the mountain grades at 4000 RPM, in 2nd gear, watching traffic pile up behind me wasn't my idea of fun. That was a 2001 Dodge 2500 with the 360 gasser engine.
Heck, that truck had to downshift out of OD to climb those grades when running WITHOUT the trailer. I then later drove my 2002 2500 Dodge/Cummins (with a 3.55 axle ratio) from home all through the Canadian Rockies to go to a wedding - didn't take the RV. The truck never downshifted once climbing the grades. Towing the RV, it would downshift on some hills, but it mostly stayed in OD, and the turbo just spooled up when climbing.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
overw8chevy
florida
Posted: 02/17/11 09:25am Link  |  Print  |  Notify Moderator
I'm humoring myself now trying to figure out if the OP was a question or a observation
mkirsch
Rochester, NY
Posted: 02/17/11 10:37am Link  |  Print  |  Notify Moderator
enginemasterguru wrote:
That's just silly.
Some would say 30MPH in 1st gear at 4400RPM is the dictionary definition of "struggling," especially if you're on an interstate and everyone else is whizzing by you at 55-75MPH.
Would you be able to tolerate a 250-mile trip at 30MPH and 4400RPMs? With the wife and kids? On a regular basis?
Sure you can do it to run the Bobcat across town to the next job, or haul a load of cinder blocks home from Lowes, but we're not talking about short and/or one-time things.
When you spend that much money on a truck and trailer to go camping, you tend to want to do it more than once.
BenK
SF BayArea
Posted: 02/17/11 10:43am Link  |  Print  |  Notify Moderator
One size does NOT fit all...
Also, folks range from not able to tell if there was an earthquake even if the
epicenter was between their legs...to those who can feel it hundreds
of miles away
Some love the sound of an ICE turning 5,000 RPMs for hours on end. I'm not one
of them on any of my trucks, but do love that sound on a V12 or my in-line six
2 seater...but it's a sports car, not a TV. Why I have a big block
for my main TV. My 'half ton' (heavy half of it's time) has a 'built'
small block (5.7L, ported, cam, stainless valves, 3 angle grind, flow
matched, CC'd, polished chamber and runners, Edelbrock High Raise Performer
intake, Edelbrock Performer 4 barrel, etc) and a 'built' auto tranny
with a shift kit, 'built' 12 bolt, etc it's okay and like the sound
at around 3.5K RPMs (no tach, so guessing)...but it's towing days are
over and both my daughters used to go out and beat up pony cars on the
local boulevard.
Some think nothing of driving at 80% throttle for hours on end and 100% throttle
for an hour or so climbing a mountain. NOT me, as I keep mine for a
looooooong time and like NOT to have to rebuild that often.
Many think they know more than the OEMs, so advise others who come here looking
for help, that it's okay to tow heavy while in OD and turn off the tow/haul function
It all depends... [emoticon]
-Ben Picture of my rig
Page of 8
