RV.Net Open Roads Forum: Tech Issues: My LEDs
 > My LEDs
Page of 32
C Schomer
Pueblo West, Co.
Posted: 08/15/11 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I've been shopping for leds. What does the XXSMD mean? I haven't taken enough time yet to figure that out. It's a whole bunch easier to learn about light properties than it is to figure out exactly what the led sites have to offer and how they compare to incandescants! I bought some cheapie 1141 leds on ebay yesterday cuz they were the lumens I wanted and I hope they aren't the blue/white. I also ordered an led retro kit for my 16w Thin Lite w/12" tubes and some paddle looking leds (so all the light projects outward) to replace 921s, from prudentrver.com. Craig
Sea'scape
Vancouver Island
Posted: 08/15/11 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
How have you installed the 36 LED board so that it stays up? I have used the double sided tape it came with, but find that it will let go from the heat of the LEDs.
I am going to try some other double sided tape I have, and hope that it will hold. My fixture has a steel backing with a recess in it. I tried to fill the recess with double sided tape, but will try to improve on the next go around.
eric1514
AZ ID
Posted: 08/15/11 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I used the tape they came with but I was meticulous when I cleaned the fixture with alcohol to remove grease and dust. So far so good.
If and when the tape fails, I will use a hot glue gun. That's what I used in the fridge and it's holding. No heat there, but lots of cold. You could have someone hold the board with the LEDs and then run a bead of hot glue around the edge instead of trying to fill the back curve of the receptacle.
Good Luck,
Eric
2015 Travato 59g
BluegrassBill
Woodland, Wa. USA
Posted: 08/16/11 12:30am Link  |  Quote  |  Print  |  Notify Moderator
Take the tape off and use a dab of RV Silacone
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
tenbear
Northern Vermont, USA
Posted: 08/16/11 05:14am Link  |  Quote  |  Print  |  Notify Moderator
I tried removing the tape but I was afraid I would damage the board, it sticks very good to the board. Instead I stuck a piece of paper to the tape and used a dab of Amazing Goop. Still there after several weeks, no sign of overheating.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
KendallP
Probably the office
Posted: 08/16/11 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Surface Mount Diode. They're the little flat ones with the yellow circle on top vs. the ones with the little glass bulb. I think they put out more light per the given volume they take up. Therefore you can pack more light into a little bulb or panel... perfect for RV applications.
If they didn't say "warm white," then they are probably blue-white.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (Don't laugh...
Unlike our credit cards... she's paid for)
pkunk
Questa, NM
Posted: 08/16/11 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Where "XX" would be the number of them. (24or36)
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
ksg5000
Oregon
Posted: 08/16/11 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update - this thread is great!
Kevin
Dave-Sparky
Sequim, Washington
Posted: 09/29/11 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I did a bunch of bench testing of the 36 SMD led panels when I got them for my trailer.
Info Here
I have now had them in all of my fixtures for about 8 months using the provided double stick tape and have had no failures out of 16 units installed. Some have been on for up to 4 hours, so they should have reached maximum heat by then.
All in all I am very pleased with this upgrade and the quality of the light I get.
Dave
Dave and Colleen
Colleen's Beach House
1991 Dutchman TT 24FK
2007 Chev Avalanche AWD
KendallP
Probably the office
Posted: 09/29/11 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Info Here
Dave
Sweet!
Nice report! Good to know. Think I'll add this to the OP.
And I might just have to pick up a few more now. Thanks!
Page of 32
 > My LEDs
