RV.Net Open Roads Forum: Tech Issues: My LEDs
 > My LEDs
Page of 31
tenbear
Northern Vermont, USA
Posted: 03/03/12 05:55am Link  |  Quote  |  Print  |  Notify Moderator
The sticky pad may not reach the fixture in the center but the edges should hold it. I have found that using some fine sandpaper to roughen the plastic a little where the sticky pad does contact the fixture helps it to stick better.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
gandude
east bay
Posted: 03/03/12 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
They have a "10 pack" on ebay and ordering them today.
...Tenbear,
That was the Comanche chief on The Outlaw Josey Wales, a great scene!
Tahoe 21WTB Toyhauler
06 Dodge 3500 SLT, QC, LB, 4x4, 5.9, auto 370's
03 Kawasaki 360 Prarie
03 Kawasaki 300 Bayou
79 Honda XL 250
12 Honda XR 650
mena661
Posted: 03/03/12 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
mena661 wrote:
Whew! Looks like posted the wrong link. I DID buy the correct color. THIS is the one I bought.
Ok, finally got around to installing this. I have one fixture with three 1156 LED's from HERE. The ebay one looks the same in brightness and color as those. And I paid $15 each for those.
Trojan L16 6V's 740 Amp-hours
bigfootford
Fair Oaks, California
Posted: 03/04/12 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
I would assume that the cheaper ones do not have the regulator.
Although we have not had many/or any report of failures due to no regulation I do like the regulator built in.
It would be nice if someone would take apart one of the cheap ones and see if they do in fact have a regulator or just resistors.
Guess someone could load up their batteries and get the battery voltage down into the low 12's then remove the load and see if the cheaper led's dim and brighten...The regulated led's do not change brightness with battery voltage.
I have almost all of my lights replaced with the regulator models, I plan on ordering some of the cheap ones for the remaining lights.
If no one has delved into determining the lack or presence of a regulator I will do it.
My solar system will temp adjust, so during bulk mode I do see 15.0 vdc. I would think that would push the non regulated led lights to the limit. Usually these type of leds limit out at about 25milliamps.
Repeated pushing will greatly reduce reliability/life expectancy.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
tenbear
Posted: 03/04/12 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Jim, since you don't say which LEDs you include among the "cheaper ones" its hard to say if they have regulators or not. Usually the regulated ones are listed as 12-30 volts, or some such range. Unregulated ones are listed as a specific voltage, ex 12 volts.
Some work was done, check out this Link by Dave-Sparky.
KendallP
Grants Pass, OR
Mena has already agreed to do this. Where ya' been???
That's kind of a bold statement. Are you positive that it will "greatly reduce reliability/life expectancy?" Link, please???
Jim
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
camperpaul
Wherever I park my travel trailer
Posted: 03/04/12 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Stuff you need to know:
LEDs are current operated devices.
The forward voltage drop in an LED is ~1.2 Volts (varies with temperature).
The light output is a function of the forward current.
The forward current is kept at a safe value by using a "buck regulator" or with a "series resister".
Buck regulators generate RFI; series resistors do not.
There is an integrated circuit called an "LM217" regulator that can be wired as a programmable analog constant current regulator. Because it is an analog device, it generates NO RFI. It will perform quite nicely over the input range of 9 to 37 Volts in this application.
The LM217 can be used as the basis of an LED dimmer.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
Salvo
California
Posted: 03/04/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I had a MR16 fixture led light that failed. I busted apart the glass casing to determine its failure. Besides the leds the light contained a resistor and a bridge rectifier IC. The rectifiers allow the light fixture to be powered reverse polarity and still work. In my case the resistor was poorly soldered and it came loose. After soldering the resistor back in, the leds worked again.
Sal
mena661
Posted: 03/04/12 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I really need a 2000W inverter so I can do these types of tests in a timely manner. Or at least that's what I'm going to tell the DW.
bigfootford
Posted: 03/04/12 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Glad Menna's going to test. Did not catch that fact.
As for excessive current:
Hundreds of links!
http://www.theledlight.com/technical1.html
LED Technical Specifications and Application Notes
Therefore, a light-emitting diode (LED) is ... is characterized by the degradation of LED ... exceeding the maximum current rating will produce excessive heat within the LED ...
http://leds-led-drivers.com/Engineering-Services/reliability-of-leds.cfm
Current Conditions Of LEDs
Because lattice defects increase with use, the luminous intensity of LEDs gradually declines. The speed of accumulation of lattice defects depends on the magnitude of the forward current.
Jim
Page of 31
 > My LEDs
