C Schomer
Buckeye, Az.
Thanks! I've been shopping for leds. What does the XXSMD mean? I haven't taken enough time yet to figure that out. It's a whole bunch easier to learn about light properties than it is to figure out exactly what the led sites have to offer and how they compare to incandescants! I bought some cheapie 1141 leds on ebay yesterday cuz they were the lumens I wanted and I hope they aren't the blue/white. I also ordered an led retro kit for my 16w Thin Lite w/12" tubes and some paddle looking leds (so all the light projects outward) to replace 921s, from prudentrver.com. Craig
Sea'scape
Vancouver Island
How have you installed the 36 LED board so that it stays up? I have used the double sided tape it came with, but find that it will let go from the heat of the LEDs.
I am going to try some other double sided tape I have, and hope that it will hold. My fixture has a steel backing with a recess in it. I tried to fill the recess with double sided tape, but will try to improve on the next go around.
eric1514
Sedona, AZ
Sea'scape wrote: How have you installed the 36 LED board so that it stays up? I have used the double sided tape it came with, but find that it will let go from the heat of the LEDs.
I used the tape they came with but I was meticulous when I cleaned the fixture with alcohol to remove grease and dust. So far so good.
If and when the tape fails, I will use a hot glue gun. That's what I used in the fridge and it's holding. No heat there, but lots of cold. You could have someone hold the board with the LEDs and then run a bead of hot glue around the edge instead of trying to fill the back curve of the receptacle.
Good Luck,
Eric
1999 24' Fleetwood Jamboree towing a 2007 Hyundai Elantra
BluegrassBill
Woodland, Wa. USA
Take the tape off and use a dab of RV Silacone
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
tenbear
Northern Vermont, USA
BluegrassBill wrote: Take the tape off and use a dab of RV Silacone
I tried removing the tape but I was afraid I would damage the board, it sticks very good to the board. Instead I stuck a piece of paper to the tape and used a dab of Amazing Goop. Still there after several weeks, no sign of overheating.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
KendallP
Grants Pass, OR
C Schomer wrote: Thanks! I've been shopping for leds. What does the XXSMD mean? I haven't taken enough time yet to figure that out. It's a whole bunch easier to learn about light properties than it is to figure out exactly what the led sites have to offer and how they compare to incandescants! I bought some cheapie 1141 leds on ebay yesterday cuz they were the lumens I wanted and I hope they aren't the blue/white. I also ordered an led retro kit for my 16w Thin Lite w/12" tubes and some paddle looking leds (so all the light projects outward) to replace 921s, from prudentrver.com. Craig
Surface Mount Diode. They're the little flat ones with the yellow circle on top vs. the ones with the little glass bulb. I think they put out more light per the given volume they take up. Therefore you can pack more light into a little bulb or panel... perfect for RV applications.
If they didn't say "warm white," then they are probably blue-white.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
pkunk
Questa, NM
Where "XX" would be the number of them. (24or36)
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
ksg5000
Oregon
Thanks for the update - this thread is great!
Kevin
Dave-Sparky
Woodinville, Washington
I did a bunch of bench testing of the 36 SMD led panels when I got them for my trailer.
Info Here
I have now had them in all of my fixtures for about 8 months using the provided double stick tape and have had no failures out of 16 units installed. Some have been on for up to 4 hours, so they should have reached maximum heat by then.
All in all I am very pleased with this upgrade and the quality of the light I get.
Dave
Dave and Colleen
Colleen's Beach House
1991 Dutchman TT 24FK
2002 GMC Safari AWD
KendallP
Grants Pass, OR
Dave-Sparky wrote: I did a bunch of bench testing of the 36 SMD led panels when I got them for my trailer.
Info Here
Dave
Sweet!
Nice report! Good to know. Think I'll add this to the OP.
And I might just have to pick up a few more now. Thanks!
