RV.Net Open Roads Forum: Travel Trailers: Hanging things from rear ladder
 > Hanging things from rear ladder
Cecilt
Page
Posted: 02/27/11 08:11pm Link  |  Print  |  Notify Moderator
Our new TT will have a ladder on the rear. Does anyone hang things like chairs or blue totes from the ladder and if so, what are you using as the accessory? tks
skipnchar
Topeka or somewhere else
Posted: 02/27/11 08:33pm Link  |  Print  |  Notify Moderator
I often strap a step ladder to the rear ladder using bungee cords. That's about the only use I've found for it
Mike_LA
Gulf Coast
Posted: 02/27/11 08:35pm Link  |  Print  |  Notify Moderator
Our friends use the TOPLINE BR1200 RV bike rack.
2006 Chevy Silverado Crew Cab Z-71 5.3L
Firestone Ride-Rite Air Springs
2005 Jayco ZX24-E Toy Hauler
Prodigy P2 Brake Control
15K Putnam Class V Receiver
10K Equal-i-zer WD
Toy Hauler
Fire Instructor
Upstate (Albany) NY Area
Posted: 02/27/11 08:36pm Link  |  Print  |  Notify Moderator
I bought an inexpensive rack that hangs from the ladder rungs, designed to hang lawn chairs from. I mount it low, and use it to support my gray/black water tote. Rack carries the weight (empty, of course!), and I use a short ratchet strap to keep it from moving.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
B.O. Plenty
Minnesota
Posted: 02/27/11 09:04pm Link  |  Print  |  Notify Moderator
I hope you can hang something from it cause i sure wouldn't climb on it. Had to laugh the other day when we went by an RV service center and a guy was on a step ladder right next to the RV ladder getting onto the roof. Light weight piece of junk doesn't look like it's good for much..
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
Golden_HVAC
Fulltime, CA, USA
Posted: 02/27/11 11:32pm Link  |  Print  |  Notify Moderator
Hi,
Those bicycles bouncing up and down can surely do damage to the ladder rack. I would not recommend more than about 50 pounds on the rack while you are towing. When going over pot holes you have up and down G forces that can be 3 times the weight when parked.
Your blue tote empty, and a couple of chairs should not be a problem. However I would put my chairs inside, so they stay clean and dry. If you do put them on the rack, they may get scratched, just make sure you use 2-4 bungy cords, and a ratcheting strap, so they don't fly off at highway speeds, and into some other car, or it's path.
Fred.
old guy
Oregon (pronounced Or e gun)
Posted: 02/28/11 01:05am Link  |  Print  |  Notify Moderator
rv accessory dealers have a hanger for the ladder so you can carry about three or four chairs on it. just tie them down real good. the guy following you will appreciate it.
Lantley
Ellicott City, Maryland
Posted: 02/28/11 04:16am Link  |  Print  |  Notify Moderator
x2
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
LarryJM
NoVa
Posted: 02/28/11 04:46am Link  |  Print  |  Notify Moderator
B.O.
Well just like normal ladders it has a weigh rating (this sticker is usually on the under side of one of the bottom two rungs) so if you don't trust the ladder installed on your TT then you should do the same with all the normal ladders.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
tvman44
Southwest Louisiana
Posted: 02/28/11 06:29am Link  |  Print  |  Notify Moderator
I bought an inexpensive rack that hangs from the ladder rungs, designed to hang lawn chairs from and only put my ladder on it fastened with a couple of bungee cords and a cable lock.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
