RV.Net Open Roads Forum: Travel Trailers: Propane Quick Connect
 > Propane Quick Connect
RUFFSTUFF
Kingsland, GA
Posted: 03/04/11 04:18pm Link  |  Print  |  Notify Moderator
So the front of my TT has a propane quick connect and everyone seems to be saying that I really cannot use it to fuel my portable grill unless I (1) tap off of my propane tanks before the regulator, thereby not using the quick connect, or (2) making up a hose and fitting to eliminate the regulator on the grill.
So if that's the case... What is the quick connect for?
I think I'm going to go with option 2, BTW.
2010 Coleman CT250
2010 Ford F250 Crew Cab 6.4L PSD
muelldawg
Phoenix, Arizona
Posted: 03/04/11 04:35pm Link  |  Print  |  Notify Moderator
I agree RS.
The "quick connect" is only for TT propane needs; not anything else. Very inflexible.
Richard & Marilyn
2010 Jayco, Jay Feather, Sport 16.5 feet
2010 Ford F150, V8, 5.4 liter
LarryJM
NoVa
Posted: 03/04/11 05:03pm Link  |  Print  |  Notify Moderator
AFAIK all these propane disconnects are for LP pressures and if you try and feed a regulator designed for high pressure propane it might not work or stop working if you are running other propane appliances at the same time. Also, even if you get it to work on an appliance with another regulator will it continue to work or shut off at the wrong time. I guess some propane grills, etc have the regulator before the grill and then gas valves on the grill and in this case the LP propane hook up I would think should work.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
janechucknicodemus
Oregon
Posted: 03/04/11 05:21pm Link  |  Print  |  Notify Moderator
Larry
I "T"'d after the regulator, I have two tanks. Then ran a hose the full length of the trailer, another "T" and two quick disconnects from a propane sale store, now have two spots to have one for a BBQ and one for my stove.
lbrjet
Liberty, IN
Posted: 03/04/11 05:40pm Link  |  Print  |  Notify Moderator
If your trailer came with a grill it should be a low pressure grill and it should work as is. If not go with your option 2 or get a low pressure grill.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
pbensen
Canton, Michigan
Posted: 03/04/11 06:38pm Link  |  Print  |  Notify Moderator
Hello,
This is a low pressure propane port, this is is used for propane appliances that do not have a pressure regulator on them. Many trailer manufactures offered a portable grill (without a high pressure regulator) connected to this port. There maybe other grills our there that are set up for low pressure.
I installed a low pressure port on my trailer. I modified my Webber Q220 to use this port. I did this by installing a T fitting in front of the high pressure regulator on the grill. I had a 20' low pressure propane hose made with a male ends of the quick connect on both ends so one end will connect to the port on the trailer and the other end connects to the grill, it works like a charm.
2002 Jayco 324G 33ft quad bunk 7200# max loaded (long trip)
2001 Econoline E-150 Traveler 5.4L w/3.73:1 rear gears
Hensley Arrow hitch and Brakesmart brake contoller
FLY 4 FUN
Alberta
Posted: 03/04/11 06:41pm Link  |  Print  |  Notify Moderator
buy a grill with a removeable regulator and you are set. The photo does not show it but the regulator hose can be unthreaded, and another hose with a quick connect can be used.
http://www.thebbqshop.com/index.cfm?DSP=ProductDetail&ProductID=2342&SubCatID=0&CategoryID=550&pagepath=BBQs_BY_TYPE/CAMPING_BBQs&id=15001
daryll
2009 Colorado 29BHS
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
Prodigy BC Reese 16K slider
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
reppoc12
NC
Posted: 03/04/11 06:44pm Link  |  Print  |  Notify Moderator
Does anyone know if option 2 would work with a Coleman roadtrip grill. I have not looked at since last year but I believe the bottle screws onto the regulator and then it connects to the back of the grill. The quick connect would be much more convenient then the little bottles.
4*phun*2
Canada
Take the regulator off the grill and install a quick disconnect.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
kemo 1
ontario canada
Posted: 03/04/11 06:48pm Link  |  Print  |  Notify Moderator
I use mine for my propane campfire. It is great.
