RV.Net Open Roads Forum: Hybrid Travel Trailers: RV movement while towing
Open Roads Forum  >  Hybrid Travel Trailers
 > RV movement while towing
2000_Kiwi
Midland, NC
Posted: 03/18/11 01:13pm Link  |  Print  |  Notify Moderator
1800gerry wrote:
Just another thing to keep in mind, if your ties are P rated then I would switch to LT. Lt tires have stronger side walls and less flex. This too would help. Just my $0.02
I had a similar issue with a used trailer I purchased. The trailer moved enough that it was scary to drive. I found the following issues.
1) the tongue weight of my TT was way to lite, I could lift it with my bare hands. So I load as much stuff in the front of the TT.
2) the previous owner put new tires on the trailer but they were car tires; I replaced them with trailer tires.
3) I added an inexpensive friction anti-sway. HarborFreight.com
A combination of all three; it tows like a dream; even when semis go by.
directboy
Farmington Hills Michigan
Posted: 03/18/11 03:29pm Link  |  Print  |  Notify Moderator
Grumpy2 a lot of stuff about this is normal, and it is not for your TV weight and size and TT. This guy above is on the right track. You could also buy a Sherline and nail down the tongue weight, then adjust the WD hitch per spec or try an Equalizer if you are looking to change.
Never had my Hybrid ever get sucked in 5 years over 3 different TV's except the first time I towed. And that's because everything on this list I had wrong.
Lifetimer
Seymour, Tennessee
Posted: 02/27/12 08:22am Link  |  Print  |  Notify Moderator
I know this thread is a year old but.... When I brought home our HHT I never felt the semi trucks go past, never felt the push or pull. I must be doing something right.
Lifetimer
2002 Dodge Ram 1500
2012 Rockwood Roo 23SS
Family of 3, Furbaby "Hope"
Seymour, TN
bonniebear1
Illinois
Posted: 02/27/12 09:12am Link  |  Print  |  Notify Moderator
If a semi is passing me on the left , I try to move a little to the right and if the semi is courteous he will move slightly to his left. That seems to help alot.
Padlin
W. Ma.
Posted: 02/27/12 10:48am Link  |  Print  |  Notify Moderator
Deleted... Didn't notice it was a year old...
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
Jayco254
Eastern Missouri
Posted: 02/28/12 11:25am Link  |  Print  |  Notify Moderator
A 21ft. trailer with the proper tongue weight and the trailer setting level or slightly nose down with the friction bar set tight enough shouldn't have any problem with trucks. Unless they're really moving and either you or them are too close to the center line.
Tom, Kathy, Nikki, & Kelly
Pets: Lady - Texas Heeler, Dinger - Rhodesian Riidgeback Mix
2008 Ford Expedition Eddie Bauer 4x4 5.4 ci 3.73 gears
2008 Dodge Ram SLT Big Horn 4x4 5.7L Hemi 3.92 gears
2007 Jayco Jayfeather EXP 254
Husky W/D, P-3
