RV.Net Open Roads Forum: Travel Trailers: Weight Distribution hitch question?
 > Weight Distribution hitch question?
marc515
New Jersey
Posted: 03/06/11 02:07pm Link  |  Print  |  Notify Moderator
Thanks guys; I think I got it.
So, considering we're getting a smaller 20-23' trailer under 5,000Lbs, which is the most recommended trailer hitch brand and model?
Best Regards,....marc & joan
TURK2500
SE Michigan
Posted: 03/06/11 02:14pm Link  |  Print  |  Notify Moderator
Reese has a nice selection of WD hitches that have integrated sway control that would be worth looking into. Also Reese, Draw-Tite, etc., have basic WD hitches as well, and you can add a manual friction sway bar.
ON EDIT: As you look at "lite" TT's, also check on the TT's A-frame for any stickers (near the ball coupler) that limits the size rating of a WD. An over-sized WD in some cases may cause damage to the TT frame.
Bob
* This post was edited 03/06/11 02:21pm by TURK2500 *
02 Chevy, 2500HD/4x4, 6.0L/4:10, GVWR 9,200lbs., GCWR 16,000lbs.
05 Jayco Eagle, 278FBS, GVWR 9,000lbs.
TV/TT loaded: 14,700lbs.
Loaded Tongue Weight: 1,300lbs.
Loaded TT weight: 8,500
Putnam XDR Class V, Reese HP Dual Cam.
othertonka
Stockton, CA
Posted: 03/06/11 02:47pm Link  |  Print  |  Notify Moderator
Basically a WD hitch will transfer 1/3 of its weight to the front axle of the Tow Vehicle, 1/3 back to the Trailer axle, and 1/3 will remain on the rear of the Tow Vehicle. SO for simple math, a 600 lb tounge weight without any WD will put 600 lbs on th erear of the Tow vehicel. Now add a properly adjusted WD hitch and 200 lbs of that weight transfers up to the front axle of the tow vehicle, and 200 lbs transfers back to the trailer axle, and that leaves the other 200 lbs on the back of the Tow vehicle. Total 600 lbs has been "Distributed", hence that is why they are called" Weight Distribution hitches". It may not be exactly 1/3 but it is close enough for this discussion and I used 600 lbs just because the math is easier. I suggest that you need a WD hitch. Hope this helps
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
270wsmhunter
Minnesota
Posted: 03/06/11 03:39pm Link  |  Print  |  Notify Moderator
When we were looking at upgrading from a popup to a travel trailer I asked tons of questions on forums, rv dealers, and even my truck dealership. I got a ton of different answers. Long story short, get the WD hitch with sway control, you won't regret having it. We upgraded tow vehicles this winter to a Silverado 2500HD and I still plan on using the Equal-i-zer hitch we used with our 1500 Sierra. I don't think one can be over cautious when towing. Also, don't scrimp on a brake controller. We purchased a P3 Tekonsha and I loved it. New rig has built in controller otherwise the P3 would've gone in it.
Good Luck.
2015.5 GMC Sierra SLT 3500 HD Crew Cab 4x4 Duramax/Allison
2011 Chevrolet Silverado 2500HD Crew Cab 4x4-Traded
2016 Jayco Eagle 284BHBE
2011 Jayco 26BH-Lost to hail
MackinawMan
NW Ohio
Posted: 03/06/11 03:49pm Link  |  Print  |  Notify Moderator
Marc, let's put it this way.
We just bought a 2000 Ford F350, which is a 1 ton Super Duty truck.
Even with that, I will still run my Equalizer Brand WD/Sway control hitch...even though our Jayco Eagle has a relatively "light" loaded tongue weight of less than 1000 lbs.
2000 Ford F350 XLT 7.3L PowerStroke Diesel CC 4x4 OffRoad SRW Long Bed
2008 Jayco Eagle 314BHDS (Momma Eagle)
Equalizer Hitch System (1400/14000lbs)
Prodigy Brake Controller
Curt XD Class V Receiver Hitch (1500/15000 lb)
L_R_G
Puyallup, WA
Posted: 03/06/11 04:47pm Link  |  Print  |  Notify Moderator
Using a WDH will also reduce the amount the rear of the vehicle will drop which will result in better handling (as long as it's setup properly). If you've got a ton of weight on the rear of the vehicle it will result in the steering not being very responsive and reduce front wheel traction. Also highly recommend sway control. The price of a WDH/sway control isn't huge and will make for a much easier time towing.
BarneyS
S.E. Lower Michigan
Posted: 03/06/11 04:50pm Link  |  Print  |  Notify Moderator
Turk2500 wrote:
...Little TT tongue weight is actually removed from the hitch ball during this process.
Just for clarification - the WD hitch does not remove ANY weight from the hitch ball during its' use. As a matter of fact, the pressure on the ball from the coupler INCREASES considerably during this time.
The reduction in weight comes at the receiver and the rear axle of the tow vehicle. There is no change at all in the actual tongue weight of the trailer.
Othertonka,
I suggest you and others take a good long look at the first post in this thread that explains how a WD hitch works.
I realize you were trying to give a simplified example but some of the things you posted are not at all accurate - especially regarding how much weight is put on the receiver or rear axle when the trailer is hooked up. You forgot to add the amount removed from the front axle and added to the rear in your example. That changes the whole example.
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Terryallan
Foothills NC
Posted: 03/06/11 05:06pm Link  |  Print  |  Notify Moderator
marc515 wrote:
ghekiere1 wrote:
the WDH distributes the wheight of the TT over the front axel and the rear axel of the tow vehicle and the axle(s) of the TT. and lets the hitch carry more weight.
But to answer your question, no the trailer will still weigh the same
Maybe I didn't phrase question properly, so I'll go about it this way.
I was looking to get a mid-sized SUV, and most of them like the Explorer, Acadia, etc have a tow capacity of 5,000Lbs, and tongue weight capacity of 500Lbs. If I get a 20-23Ft TT with a GVWR of 4,000 LBS, the tongue weight at 13% would be 520Lbs, which would exceed the 500Lb TW rating.
So I figured I would need a larger SUV like a Durango, Tahoe, etc, but not sure I would really need a vehicle that big; although a larger vehicle wouldn't have to work as hard.
But if I understand the concept of the WDH, I could get a mid-sized SUV as the WDH will effectively keep me within the 500Lb TW capacity.
Be very careful here. The mid size SUVs you are referencing, including the new Explorer, are Front Wheel Drive based. And "many" FWD based vehicles can't use a WDH. Also remeber that 5000lb tow rating is with just a skinny 150lb driver. It goes down when you put the family in it. In reality. The vehicle rated to 5000lbs, can't reall tow 5000lbs.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
fla-gypsy
North Florida
Posted: 03/06/11 05:26pm Link  |  Print  |  Notify Moderator
Yes you need a WD hitch
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
TURK2500
SE Michigan
Posted: 03/06/11 06:33pm Link  |  Print  |  Notify Moderator
BarneyS wrote:
Just for clarification - the WD hitch does not remove ANY weight from the hitch ball during its' use. As a matter of fact, the pressure on the ball from the coupler INCREASES considerably during this time....snip
Barney,
Please note that my statement was focusing only on the TT tongue weight on the ball with the spring bars engaged..., although I concur that the spring bars introduce increased load when engaged (above TT tongue weight).
In respect to my comment that "little TT tongue weight is actually removed from the hitch ball"..., I had recalled that somewhere during the course of a prior forum thread discussion it was determined that a little (of little value) TT tongue weight was removed from the ball when engaging the spring bars, my memory must be slipping! [emoticon]
Bob
