RV.Net Open Roads Forum: 4 awg Battery cable vs. 4 awg welding cable
 > 4 awg Battery cable vs. 4 awg welding cable
Page of 14
renoman69
Edmonton Alberta
Posted: 03/26/11 01:54pm Link  |  Print  |  Notify Moderator
Can some one tell me what the main difference between the two is?
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
Twomed
FL winters and then somewhere cool
Posted: 03/26/11 02:01pm Link  |  Print  |  Notify Moderator
Weldng is fine strand and very flexible. The other is very stiff. Solar? Bends and tight spaces? Get the welding cable. [emoticon] [emoticon]
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
garym114
Bluff Dale, Texas
Posted: 03/26/11 02:02pm Link  |  Print  |  Notify Moderator
Welding cable had smaller strands of copper to make easier to use and bend.
renoman69
Edmonton Alberta
Posted: 03/26/11 02:10pm Link  |  Print  |  Notify Moderator
I can get 4awg battery cable for 2.35/ft and 4awg welding cable for 1.40/ft. So do you guys think the welding cable is better? I am making up a bunch of cables to hook up charger, charge controller,inverter and such.
KendallP
Probably the office
Posted: 03/26/11 02:17pm Link  |  Print  |  Notify Moderator
I prefer welding cable, and at that price, I'd be all over it!
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (Don't laugh...
Unlike our credit cards... she's paid for)
Wayne Dohnal
Bend, OR.
Posted: 03/26/11 02:24pm Link  |  Print  |  Notify Moderator
Are you positive that the battery cable is awg, and not sae? All the products I've seen labeled as battery cables have been sae, which is smaller than the equivalent awg gauge.
Another forum member and I once compared awg and welding cable, counting and measuring the strands. What we found was that awg wire was a consistent percentage smaller than the awg spec (in the 10% ballpark), while the welding cable was right on. I'm speculating that the awg spec has a manufacturing tolerance and all the wire is built on the lower edge of the range, but I don't have access to the specs to check that out.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
Chris Bryant
Arden, North Carolina
Posted: 03/26/11 02:31pm Link  |  Print  |  Notify Moderator
From my supplier, welding cable is more expensive, but I always use it anyway. Definitely go with the welding cable.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
pianotuna
Regina, SK, Canada
Posted: 03/26/11 03:01pm Link  |  Print  |  Notify Moderator
Hi,
Another vote for welding cable.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
radiow6lar
Yucaipa CA
Posted: 03/26/11 03:11pm Link  |  Print  |  Notify Moderator
Welding cable all around! The only way....
2004 F-150 XL Supercab.
HD, 4.10 Gears, Magnaflow, Airaid, Troyer Performance Tuned Xcal I.
2006 Aljo 225LT.
240 Watt Solar, Dual T-150's, Solar Boost.
Kenwood TS-480SAT , Sierra 1800, Ten Tec Hercules II,
Dell Laptop with SL-1 soundcard interface.
time2roll
Posted: 03/26/11 03:23pm Link  |  Print  |  Notify Moderator
Battery cable is usually SAE not AWG and so it will be a bit smaller.
My preference is marine tinned AWG fine stranded wire.
Welding cable could well be more flexible and might be better for some cabling that needs to flex while in use.
675w Solar pictures back up
Page of 14
