brighteyes818
New Britain, CT
SPLENDA works great...Ants gone after one application...
powderman426
ohio
While in Fla. I had the large (like a carpenter ant) ants invade the trailer. Boraxo worked for them. The small ants like the liquid Terro and it will do them in quickly.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Father of Three
North Carolina
I've had ants many times in my camper and after trying several remedies I finally tried Terro. I agree with the above posters, it really works. I will tear a small piece of paper and put a few drops on it then place it near their trail and watch them eat. It is a bit discomforting to watch the hordes of ants sit around the bowl (the drop) and eat but keep them fed because they will take it back to the nest and your problem will be gone. I've yet to use it and not solve my ant problem.
When bought my used trailer it was infested with Acrobat ants. You can look it up and see what I'm talking about. These things were small black ants that live in wet wood which my trailer had due to a large leak. I tried spraying the ants which did kill the ones I saw but more kept crawling out. Once I removed all the wood rot and rebuilt the damaged area I started using Terro. Each day I would add more drops because they would eat every last drop. After several days of this my problem disappeared. I had a new problem though. I had small black DEAD ants everywhere.
I got re-infested last season when pulling my camper from storage. After a little investigation I found the ants were crawling up a small bush that had grown up under the camper and was touching the frame. Again, I "terro'd" them and cut the bush. I made sure this year to keep a check on the undergrowth and so far no problems.
2001 Ford Excursion 6.8L V10 Limited
2012 Sabre 32QBTS
Dear Wife, three sons (7yr, 3yr & 1yr) and one dog
Nights camped in 2012: 12
bnardini
Tehachapi, Ca.
Scottiemom wrote: We use Terro. When you first set it in their trail, they will have a party and call all their friends. They all drink up as much as they can carry, then it's back to the nest to party hardy! Next day, they're gone. The worst infestation we had was in Florida. Forget the tires, they were coming in on the hose and the electrical cord. From what I understand, it will pretty much kill the colony.
Dale
X2. Terro works great!
Bill & Lori Nardini finally on the road!
2008 Tundra SR5 doublecab
2009 Jayco 31 RKS G2
98coachman
North Idaho
Dale X3 worked great in the trailer and in my house!! No more ants
ch47d99
VA
Great suggestions for controlling the ants in the trailer. A more fun way to try outside for controlling around your site is to dump ants from one colony on another and watch WWI commence. Having lived in southern AL, I hate ants, especially fire ants so I really could care less about eradicating them in mass.
Lucas874
Kingston, NH
X2...If you have an ant problem, you most likely have some moisture somewhere as well.96_Sportsmen wrote: I've had ants many times in my camper and after trying several remedies I finally tried Terro. I agree with the above posters, it really works. I will tear a small piece of paper and put a few drops on it then place it near their trail and watch them eat. It is a bit discomforting to watch the hordes of ants sit around the bowl (the drop) and eat but keep them fed because they will take it back to the nest and your problem will be gone. I've yet to use it and not solve my ant problem.
2009 Jayco Eagle 324BHDS
2011 Ford F-350 CC Lariat 6.7
sparky723
Haskell,Tx
I no longer own this trailer.
Have used Terro before. It works!
doxiluvr
Tucson-AZ
We very seldom have had a problem with ants, but I have used Terro. I put them where I know our little dog won't get to them. I try not to leave anything out on counters that might interest them and I wipe off the counters often with something like 409 or whatever. I also mostly store stuff in containers with lids and wipe off the syrup bottle, etc. I also feed the dog in the trailer and then rinse out her dish, and then just leave out her water dish.
I agree about fire ants though as we used to live in Texas. They are mean buggers and just one bite can give you problems for a long time.
Keep some Raid ant spray around and spray any openings to the trailer. Good luck.
2006 Keystone Sprinter 300fkms
2007 Silverado 2500 Duramax Diesel 6.6 - Allison 1000 6 spd. auto. tran.
1 high school sweetheart hubby - 1 longhaired mini-dachshund, Hannah
4 grown kids, 6 grandkids
1 2007 Yamaha v-Star 1300
anaro
Mebane, NC
To keep them from getting in once the problem is fixed.... we spray the ortho home defense or another equivalent around anything on the trailer that touches the ground. We will also spray any ant colonies we see at a campsite (tons of them in myrtle beach). If we are in a heavy ant area (ie the beach) we will also put ant stakes in the ground. Has worked well so far.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
6 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
