chesterb
Ohio
I took the cover off of our TT this evening. We purchased this trailer last September and it is still under warranty. I noticed at the edge of the trailer the aluminum that folds over the roof was not nailed or stapled down and sticks up causing the rubber roof to not lay flat. I don't know if that made sense so I am posting some pictures below:
This goes for pretty much the length of one side of the trailer. It looks like they nailed down the other side much better but it sticks up too in a couple places but not nearly as much. Is this normal or common? I noticed that because the rubber sticks up a little bit that water collects there. I would have thought that the aluminum underneath would have been nailed down so that the rubber can lay flat. If this isn't normal, can it be fixed so it won't be a problem any longer? Any feedback or advice you can provide would be much appreciated!
Also, I noticed that there appears to be some staple depressions where it looks like the staple has come up from the wood underneath. Again, is this normal and can the staple poke it's way through the rubber?
Again, any advice you can offer is appreciated! Thanks again, and sorry for the long post.
2011 Dodge 2500 Hemi, Crewcab, 4x4, 4.10
2013 Rockwood Mini-Lite 2306
racer93
Concord nc
The staple is a real concern to me.
2010 Jayflight G2 32RLS
1989 Chevy Dually 454(Gas Guzzlin' Powerhouse)
fordsooperdooty
Get it to your dealer for an evaluation, the roof is supposed to be level for rain and the AC condensation to run off. And yes, staples will work their way thru the rubber membrane eventually.
larry cad
ohio
Typically when a rubber roof is installed over staples, there is a mylar tape installed first, over the staples, then the rubber membrane. The staple should not be in direct contact with the membrane or the rubber will fail. Definately a concern. Get it fixed. Someone at the factory screwed up.
Our Travel Blog
JJBIRISH
Butler, PA, USA
It is now yours and you own it…
Its still under warranty…
There is no better time than now to get it resolved to your satisfaction…
Get everything documented and in writing and keep a diary of anything that is said…
That said I don’t see anything that should be a major concern, with the staple being the worst I see at this time…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
reno6
Reno
If it were me I could cut the roof 1/2" or so, pull the staple, then put a 2"x2" patch of eternabond. Takes about 2 minutes. Much better use of your time then the tension of messing with the dealer and it would be fixed better then they would ever do.
pbohart
Portland, Oregon
JJBIRISH wrote: It is now yours and you own it…
X2.
You paid the premium for a new trailer (vs. used) for exactly this reason. It is up to the dealer and/or the manufacturer to fix.
My 2 cents. I have never seen rubber stretched or stressed like that on a roof. That is clearly a manufacturing error that should be fixed. Those roofs will get brittle with age and staples/sheeting stretching/stressing the rubber it will eventually tear. Probably about 2 months after your warranty wears out and the dealer will say "sorry".
Have then fix it now.
2010 Chevrolet Silverado 2500HD Diesel
2012 Jayco Eagle Super-Light 314BDS
danny5002
Oklahoma
I agree with others here. Document carefuly your problem even with dates and pictures. Take it back to your dealer for repair. DO NOT cut or tamper with the roof as it may void your warranty.
Chevy 2500HD w/6.0L
28 Ft Durango Fifth Wheel
Our trip pictures at RVTreasure.com
greende
Syracuse,NY
I agree with danny and others. It is up to the manufacturer via the dealer to make it right. You paid for a new TT and they made a BUNDLE of money off of the sale. Even if they have to remove the EPDM, fix the substrate, and replace the membrane, they will still be ahead. Plus, you will be more likely to return for more business. Good luck & let us know how this works out.
David
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
Fisherguy
Vancouver BC
Yah, don't be cutting and patching it, you shouldn't have to do that on a brand new traielr.
If there's 1 staple you can see now there will probly be more showing eventually, get it to the dealer.
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
