RV.Net Open Roads Forum: Class A Motorhomes: House Battery Bracket Replacement
 > House Battery Bracket Replacement
Blackdiamond
So. Cal
Posted: 04/13/11 04:47pm Link  |  Print  |  Notify Moderator
I @@@@%%$ when I saw the cost of those hold downs ($18.50/ea at my dealer). I went to home depot and bought plumbing strapping and looped it through the plastic slot in the battery and screwed it down on the threaded bar with a nut and washers, has worked great so far.
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC
02 200 EXC
07 Rhino, long travel, 4 seater
newxmar
East Otis, MA
Suggestions:
1. Standard battery hold down bolts and brackets are available at many places, may need to modify. That is what I did as the OEM hold down strap and brackets were eaten away in time.
2. Place a board under the battery. It soakes up any acid and it evaporates without damage to the board or metal bracket.
3. Place the right diameter vynl tubing over the battery hold down bolt threads. The plastic tubing will prevent the threads from oxidizing.
4. Don't overfill the battery as acid will come out and corrode everything.
Gadget Man
Posted: 04/13/11 06:12pm Link  |  Print  |  Notify Moderator
UPDATE:
My job took me to the San Fernando Valley today in Southern Cal. While there, I stopped in at Niel’s RV in North Hills, where I originally bought my coach. I told the parts manager what I was looking for. He knew immediately what I was talking about and said he had plenty of the battery brackets in stock. He said the brackets are still manufactured by Fleetwood. They are part no. 090095.
The brackets are $6.85 each and are beefier than the original ones. The manager said Fleetwood wants a fortune for the threaded rods and suggested I make my own...they seem simple enough to make. Mine have some surface rust only, so I think I’ll just clean them up a little and throw some Rust-Oleum on them. The top brackets are my main complaint. As you can see by the photos in my OP, they are corroded away.
If anyone needs any of these brackets, I highly recommend Niel’s RV. Their phone number is 818-891-2166. Ask for Mario.
Craig
My wife does all the driving - I just hold the wheel...
2005 Providence 39J
2007 Tacoma Double Cab Dingy
Thousand Trails, Coast to Coast, RV Golf Club and Elks Members
DSDP Don
Moorpark, Ca
Posted: 04/13/11 09:52pm Link  |  Print  |  Notify Moderator
Craig....If you had driven about 15 miles farther west, I would have welded you up a set for free. I'm across the street from the MPK MetroLink Station. You weren't on duty were you? [emoticon]
Don & Mary
2014 Newmar Dutch Star 4018 - All Electric
Cummins 450ISL
2016 GMC Canyon 4WD Crew Cab
Gadget Man
Posted: 04/14/11 06:15am Link  |  Print  |  Notify Moderator
Darn...yes I was. Thanks for the offer Don. Little too far out of my RD, but I could have made it after work. [emoticon]
Craig
