RV.Net Open Roads Forum: Tech Issues: Valterra or Bristol Waste Valve
 > Valterra or Bristol Waste Valve
NEOK
Oklahoma
Posted: 04/17/11 07:11pm Link  |  Print  |  Notify Moderator
I need to replace the 3" Bristol waste valve on my black tank. I see a lot of places selling the Valterra Bladex valve and not many of the Bristol valves. I think Valterra makes the Bristol valves. Does anyone have any experience with using a Valterra valve instead of a Bristol valve?
Thanks
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
brirene
midwest
Posted: 04/17/11 07:22pm Link  |  Print  |  Notify Moderator
Haven't used a valve, but several other Valterra pieces and have never had a problem with them.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
camperkids1025
Bel Air, MD.
Posted: 04/17/11 08:42pm Link  |  Print  |  Notify Moderator
I just replaced both the 3" black and the 1 1/2" gray valves with Valterra valves that's what was on it. Jim
The Camperkids Jim & Lois
3 Grandkids Maria, Christian, Antony (part timers)
1999 Newmar Mountain Aire 37.5ft, Ford V-10, F-53 Chassis, Bilsteins Shocks W/ Bilstein Steering Stablizer, HWH Levelers
bill h
hassayampa valley
Posted: 04/20/11 12:38am Link  |  Print  |  Notify Moderator
I like Valterra valves because they work and new seals are available most RV stores. Use stainless bolts and nuts. I replace the seals every 5 yrs or so
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
Snowman9000
IL
Posted: 04/20/11 08:01am Link  |  Print  |  Notify Moderator
I don't think they are part of the same company. Bristol is in Elkhart, and Valterra is in California. I bought a Bristol 1.5" valve and a Valterra one, and the Bristol body is thinner, but the seals protrude more. You might have a tight squeeze fitting the Valterra in there, I dunno. Valterra says theirs replace a Bristol. Well, everything lines up the same, but the width might depend on if you have any wiggle room.
I bought the Bristol at Pontiac RV in Pontiac, IL. They are on the web, I think. Didn't notice if they had any 3 inchers.
Lube up the mating surfaces with petroleum jelly or bearing grease to make it easier to slide in without distorting the seals.
2014 Sunseeker 2300 Class C (Chevy 4500)
bill h
hassayampa valley
Posted: 04/20/11 10:33pm Link  |  Print  |  Notify Moderator
I use Crisco. Being a vegetable product, it is less likely to hurt the rubber than a petroleum product..
