RV.Net Open Roads Forum: Class A Motorhomes: Hot Water Heater not turning off
 > Hot Water Heater not turning off
Go Dawgs
Kent, WA
Posted: 04/21/11 06:10pm Link  |  Print  |  Notify Moderator
I have an Atwood hot water heater in my 87 Allrego Bay MH. Yesterday I fired it up to completely heat the tank and it seem to never shut off. After about 15 minutes I noticed that water was coming out of the relieve valve.
1. Is that normal? In my TT that never happened
2. Am I correct in that after the temp. has been reached the HWH is supposed to turn off?
Thanks
Arnold
2004 Ford F350 Lariat 4x4 Dually
2017 Grand Design Reflection 303 RLS
michahicks
Waterford/Gaylord, Mi
Posted: 04/21/11 07:01pm Link  |  Print  |  Notify Moderator
That heated water is expanding. There's very little room for it to do that in the water system. Water seeping from the pop off is normal on the initial warm up. At some point, yes, the burner will turn off, though it does take a few minutes.
1997 38' HR Endeavor, 275 Cat, Freightliner
2003 CR-V Toad, Blue Ox, Ready Brake
SS Slacker
Lino Lakes, MN
Posted: 04/21/11 07:06pm Link  |  Print  |  Notify Moderator
Agree with the previous post...if you "just filled it" then the water was probably pretty cold, which takes longer to heat and the expansion is more than normal. When I start out the first time, I occasionally open a Hot faucet for a brief moment to relieve pressure during the initial heat up process.
Dan & Tracy
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
Go Dawgs
Kent, WA
Posted: 04/21/11 07:09pm Link  |  Print  |  Notify Moderator
Thanks I will try that this weekend
rv2go
Fulltime 15 yrs (Knoxville, TN).or someplace else
Posted: 04/21/11 07:16pm Link  |  Print  |  Notify Moderator
It may help the leaking pop off if you re-establish the "Air Cushion" in the top of the tank.
1. Turn off the heat source. Electric or Gas
2. Turn off the water. Pump or City
3. Open a Hot water faucet inside the RV to release pressure.
4. Raise the lever on the pop off valve.
5. Remove the drain plug and let the water drain.
6. Replace the drain plug.
7. Put the pop off lever in the closed position.
8. Turn the water on.
9. When the inside faucet quits blow air and water is running,Close.
10.Turn on the Heat source.
When the water heater reaches the thermostat setting, it should turn off.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
halibutman214
Oregon
Posted: 04/22/11 07:37am Link  |  Print  |  Notify Moderator
BINGO! All I've ever done was step 1 thru 4. The air cushion is between the top of the tank and the relief valve, or at least it is on most of these. All you had to do was lift the relief valve until water stopped running and then close it.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
tony lee
Iceland 10 weeks, India 4 weeks, US & Mexico 16 we
Posted: 04/22/11 08:02am Link  |  Print  |  Notify Moderator
That will give you a small air cushion, but for best effect (maximum possible cushion), follow the entire procedure.
As for the OPs problem. How fast is the water leaking out of the relief valve.
A small driibble that stops once the water reaches the temperature may be OK (but shouldn't happen at all if the air cushion is correct), but if the water is running continuously then the water may never get hot enough to turn the heater off because of the cold water flowing in (this will also be indicated by your water pump running more than it should be). If the leak is major, try lifting the lever and letting it snap shut several times and any debris keeping the valve open might be flushed clear.
Tony
Lots of photos with comprehensive captions at MY PICASA Album
Spotwalla map of our travels - Our Travel map
Clay L
Palisade CO
Posted: 04/22/11 11:28am Link  |  Print  |  Notify Moderator
The following is info from the Atwood service manual on how to properly establish the air pocket.
Step 1: Turn off water heater
Step 2: Turn off incoming water supply
Step 3: Open the closest hot water faucet in the coach
Step 4: Pull handle of pressure-temperature relief valve straight out and allow water to flow until it stops.
Step 5: Allow pressure-temperature relief valve to snap shut, turn on water supply and close faucet.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
halibutman214
Oregon
Posted: 04/25/11 01:12pm Link  |  Print  |  Notify Moderator
That's why I did it this way.
Clay L
Palisade CO
Posted: 04/26/11 08:43am Link  |  Print  |  Notify Moderator
As your post said you did it right.
I just wanted to emphasize that it's not necessary to remove the bottom drain valve.
