RV.Net Open Roads Forum: Tech Issues: 120V Electrical Mystery
 > 120V Electrical Mystery
HotelOne
West Slope, Central Sierra Nevada
Posted: 05/01/11 12:53pm Link  |  Print  |  Notify Moderator
Hi All;
I have an 120V electrical mystery I hope you can help me with. In troubleshooting why my Norcold fridge wasn't working on 120V I tested the voltage at the 120V socket in the fridge I found only .94V. I then checked all the other 120V sockets inside the camper and found the same thing, around .94V. No 120V device will run off those sockets. All three breakers are on and have been flipped on and off. I'm getting a good 120V from the socket on my house that the camper is plugged into. On my last trip I was running the camper off my Honda 2000i generator since there was no shore power. I understand these units have very good power protection. What do I check next? I hope this is something simple and not the wiring! TIA.
Vince
2001 Dodge Crew Cab 2500 4X4
2006 Lance 8SCS (845)
HotelOne
Posted: 05/01/11 01:02pm Link  |  Print  |  Notify Moderator
Disregard! I found the GFI on the socket over the sink was tripped. Apparently this puts down the entire 120V system. Thanks!
Vince
camperpaul
Wherever I park my travel trailer
Posted: 05/01/11 04:45pm Link  |  Print  |  Notify Moderator
Goll-dang - 9 seconds to fix the problem...
A new record?
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
renoman69
Edmonton Alberta
Posted: 05/01/11 06:20pm Link  |  Print  |  Notify Moderator
....well 9 minutes.... but still a record!
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
HotelOne
Posted: 05/01/11 06:25pm Link  |  Print  |  Notify Moderator
I was down to almost no options when I posted. Then I stumbled on the GFI right after my desperation post. Made the stupid look smart I guess... Thanks again.
Vince
frankfish
florida
Posted: 05/01/11 06:37pm Link  |  Print  |  Notify Moderator
Doesn't sound right. If properly wired, a tripped GFI should have no effect at all on voltage available to other loads/outlets. Might want to check further.
Bobbo
Wherever I park
Posted: 05/02/11 08:10am Link  |  Print  |  Notify Moderator
I disagree. If the other outlets are wired to the LOAD side of the GFI, they would also have been disabled.
Bobbo, Linda and the furry kids (1&1/2 German Shepherds)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
2010 Subaru Forester w/BlueOx baseplate & Ready Brute Elite towbar
CROSSBOLT
Whiteville, TN USA
Posted: 05/02/11 10:06am Link  |  Print  |  Notify Moderator
Bobbo is right. Although the reefer outlet is usually on its own breaker and not chained to a GFCI.
Karl
Karl
javaseuf
California's Gold Coast
Posted: 05/02/11 06:01pm Link  |  Print  |  Notify Moderator
Karl
Many of the fridge outlets I have come across over the years are wired to a GFI since the outlet is located outside in a weather resistant (not weather proof) compartment.
