RV.Net Open Roads Forum: Beginning RVing: Blocks under jacks - newbie question
 > Blocks under jacks - newbie question
RoyB
King George, VA
Posted: 05/06/11 10:27am Link  |  Print  |  Notify Moderator
I use 2X8 wood blocks for my setup. They give me a level surface for the jacks and also keeps me from cranking down the jacks for a long distance. Mine are more stable with the short extension distance.
My POPUP has a stablizing jack for each corner and one under the tongue. For some reason I always put my two longest 2x8 wood blocks under the front two corners of the POPUP. Seems to stablize the POPUP movement better when we are walking around inside.
I always get my trailer somewhat level front to back and then always have a slight tilt front-side to back-side to allow for water run off (from Rain as well as A/C) to flow to the back-side of the popup trailer. I also always drop one side the awning lower than the other to control water run as well and not let 40 gallons of water to pool up in the awning. It pooled up on me so bad one morning I couldnt even open the trailer door to get out haha... Cant believe how strong those awnings are...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
mking
Indianland,South Carolina
Posted: 05/06/11 11:02am Link  |  Print  |  Notify Moderator
X2 What Skip said.And if were staying a week or more I also have 3 more screw jacks I use.2 in the middle on the frame and 1 under the steps.
2006 Dodge Quad-Cab 2500 CTD,4;10 gears,pulling a Forestriver Flaggstaff 831qbss
NanciL
Bakersville, NC, USA
Posted: 05/06/11 04:16pm Link  |  Print  |  Notify Moderator
You get much more stability if your jacks are not extended vertically.
I made up four wooden boxes that I use under my stabilizers, and I also have a larger one that I use under the tongue jack.
I used to use the lynx lock ones, but now only use them for leveling the trailer.
Jack L
Jack & Nanci
garry1p
Oklahoma
Posted: 05/06/11 06:24pm Link  |  Print  |  Notify Moderator
To laze to crank them all the way down and to tired to crank them all the way up when it's time to go.
Other than that as others have said better stability the shorter the cranking distance and no dents in the asphalt.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Arcamper
Fayetteville, AR
Posted: 05/11/11 02:50pm Link  |  Print  |  Notify Moderator
I always love to watch the people set up that bring enough wood to build a treehouse. I guess its just what you are use to but I don't put blocks under the jacks.
2007 Keystone Laredo 29RL 5th
2008 Dodge 2500 Quad Cab SLT HD 4x4 6.7 Cummins with EB,6 speed auto
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
1994 Chevy 1500 5.7 extended cab PU
Pullrite 16k Superglide with Super Rail kit
Brakesmart & Prodigy P3
rpounds
California - I'm not old, so how am I a
Posted: 05/11/11 04:12pm Link  |  Print  |  Notify Moderator
beemerphile1 wrote:
With many stabilizer jacks they have more movement the further they are deployed. By using the blocks it isn't necessary to extend the stabilizers as far and thus there is less movement of the RV.
X2
'05 Dodge Ram CTD Quad Cab 4x4
'11 Dutchmen 277RLS
Our Blog
KKELLER14K
BEAVERTON OREGON
Posted: 05/11/11 05:25pm Link  |  Print  |  Notify Moderator
I put plastic blocks under my TC jacks because the feet put stains on the concrete. When it's on the truck, I use 4x4 extensions so I don't have to run the jacks very far down to stabilize the movement.
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 05/12/11 04:56am Link  |  Print  |  Notify Moderator
rpounds wrote:
X2
X3
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
ExRocketScientist
Laurel, MD
Posted: 05/12/11 08:57am Link  |  Print  |  Notify Moderator
I have a concrete driveway where mine sits most of the time with the stabilizers down, no wood. Works well. When camping, I will put a stack of lynx levelers down if the stabs would need to go down more than halfway (for stability like others said). I used to have big 11" cube wood blocks I made for this out of 6x6s, but they weighed 24 pounds each. A stack of 10 lynx levelers is 10" high and weighs 8 pounds (the replacement was part of my weight reduction campain to get some margin on my China bombs).
I once put a fence board under one of my landing gear jacks in a wet grassy field. I didn't have the trailer chocked tight enough and actually saw the landing gear jack slide on the wet board. I have since set up in the same place under the same conditions, but I never put anything under my landing gear jacks anymore. The bottom were coated at the factory with that rubberized undercoating. I put them on terra firma and they don't move. If you have a tongue jack, I would spray the bottom with undercoat, and always put it on terra firma unless someone prohibits you from doing so.
ERS
meandmydeere
Sparta, Michigan
Posted: 05/16/11 08:32am Link  |  Print  |  Notify Moderator
This is my reason for not using blocks. When you back under your 5th wheel, if you haven't jacked up the trailer quite high enough, the jacks slip off the blocks, and the front of the trailer drops on top of the bed of the truck. Now one of 2 things are going to happen, maybe 3. 1st is, you say things like, I won't say it here so you fill in the blank __________, second thing is, you call your insurance agent and tell him what you just did, or if your lucky, you can get some nice aluminum diamond plate top bed rail caps to cover up your stupidity.
No reason to ask how I know all this twice!!!!!!
Mark J Scholten, Sparta, Mi and Mission, Tx.
Antique tractor collector, Extra class amateur radio op AB8MS
Freightliner s/a semi tractor, 48' spread axel drop deck, '03 27 foot Cougar 5th wheel,'08 Dodge Ram 2500 diesel 4x4, 2013 Palomino Maverick 2902
