RV.Net Open Roads Forum: Fifth-Wheels: how do they measure the 5th wheel length
 > how do they measure the 5th wheel length
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 05/07/11 07:34am Link  |  Print  |  Notify Moderator
how do you measure a 5th wheel trailer length. if they say it is a 30foot is that from bumper to king pin, bumper to end of truck bed, or overall length. thanks ED researching 5er for replacement of a pull trailer ED
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
Dennis M M
Winter in Tucson, AZ; summer on the road
Posted: 05/07/11 07:38am Link  |  Print  |  Notify Moderator
From what I understand it varies by manufacturer. Our Newmar is listed at 35', but is actually 37.5' overall. I seem to recall reading somewhere that one mfg. measured from the ceiling in the bedroom to the floor in back!
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
Chris
Shelter Bay, Wa
Posted: 05/07/11 07:40am Link  |  Print  |  Notify Moderator
Generally 5th wheels use to be messured inside back wall to inside the front wall. My 2005 Cardinal 29WBLX was messured that way. It is around 31.5 foot overall in lenght. Each manufacture seems to have gone off it their own direction in recent years.
Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
Joy
Henderson KY 42420
Posted: 05/07/11 08:00am Link  |  Print  |  Notify Moderator
Ours was from king pin to bumper.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Mr. Black
South Hill, Washington
Posted: 05/07/11 08:23am Link  |  Print  |  Notify Moderator
There seems to be no rhyme or reason to it.
Our current Sierra is advertised as a 28 footer but it tape measures at 31.5 feet without the bumper or the pin box.
I heard a a few say it is based on the livable floor space inside the trailer, but I am not so sure on that one either.
Steve
2006 Ford F350 6.0 PSD CC 4x4 LB, Bone Stock. B&W Turnover / Companion. Airlift Airbags 57291. Leveling Kit. RS9000 Shocks.
2012 Heartland Sundance 3100RB 5th wheel. 36' @ 12k pounds.
n7bsn
Yes
Posted: 05/07/11 09:16am Link  |  Print  |  Notify Moderator
Mr Black has nailed it, I can even show you where, in the same line from one builder, where their "26" was longer then their "27"
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
bpounds
Senile, er I mean
Posted: 05/07/11 09:36am Link  |  Print  |  Notify Moderator
Your actual overall length, which will be listed on the specifications sheet, is from pin to bumper. But what they call it, and their model designations, are all over the map and often make no sense. I believe these are intentional misrepresentations, and it makes me angry, but I guess they can call their product whatever they want. But the specifications sheet had better not lie.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Allworth
Orlando, FL
Posted: 05/07/11 09:41am Link  |  Print  |  Notify Moderator
The "length" is assigned to each floor plan by the Advertising Department. The Overall Length quoted in the specifications is "usually" front cap to rear bumper or king-pin to rear bumper. There is no industry standard.
Look at my signature. The Titanium is a cab-over design with the front bedroom out over the cab of the truck. "30" is king-pin to rear bumper. "E" is "extended". "35" is nose to tail. Again, everything is rounded. My actual king-pin to bumper is 30'-5" and my actual overall is 36'-9". When I make reservations, I tell them it is a thirty-five foot, fifty Amp, fifth wheel.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
Chris
Shelter Bay, Wa
Posted: 05/07/11 09:49am Link  |  Print  |  Notify Moderator
Allworth! With boats we call that bragging or paying moorage! Chris
donn0128
Pronounced Ore-gun
Posted: 05/07/11 10:48am Link  |  Print  |  Notify Moderator
There is no correlation between model numbers and actual size. Your fiver is MODEL28XXX and the size is 31+ feet long. Some manufacturers use the model number as an indication of frame length. Others don't Still makes no difference. The actual length will be listed on the manufacturers web site. IF you want to find out for yourself. tape measure from the rear bumper to the farthest point front. That is your actual length.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
