RV.Net Open Roads Forum: Fifth-Wheels: Found our "perfect" trailer
 > Found our "perfect" trailer
larry barnhart
wenatchee. wa usa
Posted: 05/10/11 05:13pm Link  |  Print  |  Notify Moderator
WAFlowers. You are doing it right.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
WAFlowers
Clearwater, FL
Posted: 05/10/11 05:29pm Link  |  Print  |  Notify Moderator
Thanks Larry. Be sure to remind me of that when I get the bill from the garage!
Bill and Willemina Flowers
Sammy and Teddy (the dogpack)
2003 F350 XLT Supercab DRW 7.3L Diesel
2005 Keystone Monata 3400rl (as of 5/21/11)
(Was in a 2000 Coachmen Catalina Sport 220RK)
larry barnhart
wenatchee. wa usa
Posted: 05/12/11 12:04pm Link  |  Print  |  Notify Moderator
Ok now this is the deal WAFlowers. It won't be less money during a camping trip and loss of fun time, well you understand.
chevman
WAFlowers
Clearwater, FL
Posted: 05/11/11 08:22am Link  |  Print  |  Notify Moderator
Mike E. wrote:
When I bought my '01 F350 the cruise didn't work either.
Quick check showed there was a re-call and it was sorted out in a jiffy - hopefully yours is the same.
Checking on the Ford site, it looks like the recall does apply to my truck and may not have been done. Fingers crossed, but this might be a free repair just like you had!
campgrl
Corunna, MI
Posted: 05/11/11 08:17pm Link  |  Print  |  Notify Moderator
Congrats on your purchase. I hope it works well for the both of you. We just moved from a tt to a 5ver in Jan and have yet to use it. Maiden voyage planned for Memorial weekend just a few weeks away! When we traded in January we also purchased a used 2003 GMC Sierra 2500HD diesel. We have always leased our vehicles and going from having brand new to used was a change. When we got the diesel there was also a few things that needed attention (oil change, fuel sending unit, and gasket in transfer case). Those repairs added up to about $800, but we also had to get our hitch installed as well-another $300. We got a great deal on the truck so putting some money into it didn't seem so bad. The good thing about it was that the injectors were all recently replaced and this model was infamous for shotty injectors. I hope your repairs don't cost you an arm and a leg so you can get that boob tube for your wifey! Here's to a wonderful camping season!
WAFlowers
Clearwater, FL
Posted: 05/12/11 08:12am Link  |  Print  |  Notify Moderator
Thanks campgrl. There are very few repairs needed, and those are mostly minor things (horn wasn't working; a problem with the switch contacts that was easily corrected). Other than the cruise the biggest items I'm expecting are the maintenance: oil and filter changes, coolant flush and fill and differential.
As I was typing this the service manager called. Rear brake caliper is bad (it stuck on the drive home) but that wasn't unexpected and isn't expensive.
Countdown: 9 days until we pick up the trailer!
almo5
Northern Virginia
Posted: 05/19/11 08:35pm Link  |  Print  |  Notify Moderator
WAFlowers,
Welcome to the Montana family! We too have an 05 3400RL. Love it!! Enjoy your new Monty!!
Almo5
2000 Ford F-450 XLT CC 7.3 PSD DRW
2005 Montana 3400RL
WAFlowers
Clearwater, FL
Posted: 05/19/11 08:55am Link  |  Print  |  Notify Moderator
In the end we replaced both rear calipers, a rotor, the master cylinder, AC compressor (not a leak after all, and it already had a new condenser and evaporator), water pump and more.
Yesterday we had a Curt Q5 20K hitch installed and a Reflex brake controller as well as a 7-pin connector put in the bed. The rails just cleared the plate which had been welded in to support a gooseneck ball, so now we have both.
Today it is going to a Ford dealer for 2 recalls: the cruise control and camshaft position sensor.
Saturday we get the "new" trailer.
nremtp143
Georgia
Posted: 05/19/11 12:28pm Link  |  Print  |  Notify Moderator
If you take care of the 7.3 , it will take care of you. Still one of the best diesel engines out there. Congrats on your purchases and we all would like a couple of pics when you get them hooked up. Happy camping.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
WAFlowers
Clearwater, FL
Posted: 05/12/11 12:30pm Link  |  Print  |  Notify Moderator
Truck now has an appointment next week to get a Curt Q5 20K 5th wheel hitch and a Curt Reflex brake controller installed, with the plug put in the bed of the pickup.
